Old 03-04-2019, 07:56 AM
pilp pilp is offline
Default [SOLVED] Babyface Pro not sending audio input signals to Pro Tools
Hello,
Pro Tools is not receiving any input signal from Babyface's Pro I/O. PT's I/O page is perfectly routed with everything in its place. The hardware page has Babyface Pro as PT's active audio interface.
I can hear the input signal coming in when I bring the direct-monitoring levels up on the Babyface Pro, but PT 2018.12 is not receiving any signal from Input1/2. I have set the audio track's input to INPUT 1/2, armed the track for recording and everything. Zilt.
All other DAWs I have (Logic, Ableton, DP) are fine, so the routing on TotalMix is spot on. The issue is within Pro Tools.
Help please?
Thank you so much!
Old 03-04-2019, 11:15 AM
Default Re: Babyface Pro not sending audio input signals to Pro Tools
Found the answer.
Apparently, Mac OS Mojave was blocking access to my RME's analog inputs, so I had to go to system preferences, and grant PT some OS privileges.
These two items must be checked:
System Preferences > Security and Privacy > Microphones > Pro Tools
System Preferences > Security and Privacy > Accessibility > Pro Tools
If any of you go through the same issue, this could probably be the solution.
Old 11-12-2021, 11:06 AM
Lonlie Lonlie is offline
Originally Posted by pilp View Post
Found the answer.
Thanks a lot !
Pro Tools 12.5.2 Simply not Getting Input Signals from Apollo sandcastle Pro Tools 12 2 09-24-2016 03:43 PM
MIDI Out signals stop sending, restart when I unplug/replug cable el biciclista Pro Tools TDM Systems (Mac) 10 07-30-2003 07:49 AM
still get input signals with input gains down MrShayne 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 06-22-2003 10:21 AM
Can external audio signals be digitally looped in and out of Pro Tools RDJ General Discussion 2 04-11-2001 06:52 PM
MONITORING INPUT SIGNALS OHENEBA 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 01-30-2001 08:31 AM
