Head Room
Hey, I recently got a Digi001, i'm happy with the quality or the recordings...but not with the over all volume of everything when i'm done. Can you guys give me some pointers on how to get more power/levels out of my recordings? (so some one won't have to crank they're sterio for it to sound decent)
thanks!, -Travis [ July 08, 2001: Message edited by: Travis Mitchell ] |
Re: Head Room
This has absolutely nothing to do with the Digi 001. This is a common problem to any recording. I don't know if you've ever been to a professinoal recording studio, but you'll find that even your tapes/CDs from there with have a weak signal.
The solution to this is, of course, mastering. Preparing the material for it's destination medium to ensure the best quality and signal/noise ratio. If you're not interested in full-out mastering of your material, simply invest in a brick wall limiter and you'll be happy as cheese. Insert the limiter on your master fader (they're not cheap, the best one's right now for LE are either the Waves L1, or digidesign's Maxim) and adjust to taste. There should be a few presets to help you out. Listen carefully, because what you're really doing is cutting off the spikes in your signal so that your overall levels can be raised without clipping. There will be a point where you will hear severe audio degredation. This will solve your problem if used correctly, however. Good luck! |
Re: Head Room
There is a plug in you can use to add gain to your tracks after they are recorded. Go to Audio Suite and it is right there you can boost your volume there. Going as hot as possible to disk is a suggestion as well.
http://drastiksolutions.11net.com |
Re: Head Room
Try the 'MAXIM' plug-in demo on the PTLE cd
Too much blood in my drugstream Motherboard: Gigabyte Z690 AERO D CPU: Intel Alder Lake Core i9-12900K CPU Cooler: Noctua NH-D15S RAM: Corsair Vengeance DDR5 64GB (2x 32gb 5200MHz) Drives: 2 x Samsung 980 Pro 2TB NVME PCIE 4.0 M.2 SSD (Record & Samples) 1 x Samsung 980 Pro 1TB NVME PCIE 4.0 M.2 SSD (OS Win 11 Pro) GPU:Gigabyte GeForce RTX 3060 12GB GDDR6 PCIE 4 PSU: Corsair HX Series HX850 Platinim CASE: Fractal Define XL R2 PT 11HD (v11.3.2) Omni s/pdif <> AxeFxIII HD 96I/O |
Head to head shoot out: Matchless D/C-30 vs. eleven rack MS-30 | Chad Pippin | Eleven Rack | 11 | 07-26-2012 07:21 AM |
HEAD TO HEAD - The Amp Simulator Shootout Project | Benoni | Eleven Rack | 82 | 12-25-2011 04:08 PM |
002 lost its head room? | brokemusician3 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 8 | 10-14-2008 09:46 PM |
How much head room is given for plugins in PT? | storm-01 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 08-21-2003 12:28 PM |
Head Room | Travis Mitchell | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 8 | 07-13-2001 05:46 AM |
