Pencil tools
Hi
I'm using a 2.4g cup , 1 G ram pc with the protools LE but I can't use the pencil tools , did anyone knows whats happening? Thanks a lot |
Re: Pencil tools
You can only use the pencil tool when you're zoomed in pretty far..
Note that the pencil tool is destructive,.. If you want to draw a change you may want to first consolidate around the aea first. Rail
Re: Pencil tools
Dear rail
I have try zoom in , zoom out all the way but still can't use the pencil tools . Thanks Dennis |
Re: Pencil tools
Pencil is "NOT" destructive. I have used it many times an then hit "undo" because I didn't like the result. Maybe there is an option somewhere to make it non or destructive. Hmmmmm
Re: Pencil tools
Try searching the "answerbase" 307. I just looked in Pro Tools to see if there was an option to turn pencil on or off and there isn't. As far as I know it should just work. You have to be really far in (to where the wave form is just a wavy line) and then click the pencil buttin then click and drag on the wave form to pencil edit it. Good luck:)
Re: Pencil tools
If you are using the pencil it is indeed destructable. But you still have your undo's. But this is one of the actions in protools that actually happens to the original file, unlike stuff like crossfading, chopping off some stuff, audiosuite etc.
What's that? - That's the machine that goes "pling". Bastiaan |
Re: Pencil tools
i love my apple iPhone! |
Re: Pencil tools
To set this, go to: SystemProperties>Advanced>Performance>Settings>Adv anced>Virtual Memory>Change Or remove some of your RAM, so you have less than 1GB I changed my paging file min and max to 1024, and it worked (on a TDM system) |
Re: Pencil tools
If you have too much memory you can't use the pencil tool? [img]images/icons/confused.gif[/img]
Re: Pencil tools
"Regardless of my zoom level or session length, I have lost the functionality of my Pencil Tool. This error was seen in systems containing 1GB RAM. Reducing the amount of RAM to 512MB resolved the error. " Changing the paging file size worked for me. Didn't wanna reduce my amount of RAM. That was the most stupid solution i've ever heard from Digi! |
Pro Tools 7.3 pencil tool not working wth? | GMP | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 04-15-2012 05:19 PM |
Pro Tools 10 Pencil / Audtion issues | BroomPole | Post - Surround - Video | 4 | 03-20-2012 08:01 PM |
my Pro Tools 7.3 LE pencil tool stopped working | GMP | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 03-11-2011 04:58 AM |
smart tools & pencil menus won't appear | klickyman | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 06-25-2007 09:40 PM |
locked pencil tools | dubC | Pro Tools TDM Systems (Mac) | 2 | 04-15-2003 08:43 AM |
