  #71
Old 04-25-2019, 10:24 PM
unkJE's Avatar
unkJE unkJE is offline
Default Re: Massenburg Design Works MDWEQ5 crahes PTHD 2018.1
Originally Posted by metalmixer View Post
Cool if you only need the Native version I wanted the DSP version - If I am stuck with the native EQ I'll stick with something else I already own.
Originally Posted by filmixer View Post
Yeh. I'm a little bummed there isn't a DSP upgrade path. There used to be. Haven't used it at all for a while because I'm in film post and I can't tolerate any bad behavior from anything I use. I might upgrade to native if reports come back that it's rock solid.
AAX DSP/Native – only the Full Price option is currently showing in the Avid Store.
However, the Upgrade option to EQ5 AAX DSP/Native is currently advertised here:
https://www.avid.com/plugins/mdw-hi-...cense-upgrades
LICENSE UPGRADES
Upgrades from MDW EQ 3 TDM or earlier MDW EQ version
In order to upgrade to MDW Hi-Res Parametric EQ 5 (AAX DSP/Native), you must have one of the following licenses on your iLok account:
• MDW Hi-Res Parametric EQ v3 (RTAS TDM)
• MDW Hi-Res Parametric EQ v2
• MDW Hi-Res Parametric EQ (this is the v1 license)
When you upgrade to v5 you will surrender your earlier license for MDW EQ. This earlier license will be replaced by your license for MDW Hi-Res Parametric EQ 5 (AAX DSP/Native), iLok license name: "MDWEQ5-AAX".
Please note: This license is for the AAX DSP and AAX Native version only, it will NOT authorize earlier versions of MDW EQ (RTAS or TDM).
What if I only have the MDW EQ RTAS version?
If you own the following iLok license:
• iLok license MDW Hi-Res Parametric EQ v3 (RTAS)
You are eligible to upgrade to MDW Hi-Res Parametric EQ 5 AAX Native*
Calling Sir Jeffro - can you please add the MDW Hi-Res Parametric EQ 5 (AAX DSP/Native) Upgrade option to the Avid Store?
Pro Tools Studio 2024.3 * SSL UC-1 * Digidesign Command 8 * TECH 21 SansAmp 2.0 * Xvive U3 2.4Ghz Wireless Microphone * Shure SM57 & Rode NT2-A * Fender 30 & Champ 12 valve amps * M-Audio Axiom Pro 49 * PreSonus Speakers & Monitor Station V2 * Lenovo W520 laptop Type 427637U (32 GB RAM) with extra-Ports Dock + SSDs: 2 @ Samsung T5 + 1 @ Samsung T7 * 3 Screens: 15.6” Laptop + 24” BENQ GL2450-B + Samsung 27” CT550 curved Monitor * best Wife!
  #72
Old 04-26-2019, 10:04 AM
elicious elicious is offline
Hey Rail,
any talk of supporting the eq curve feature?
ihatetyping
  #73
Old 06-08-2019, 05:30 AM
gos6 gos6 is offline
Default Re: Massenburg Design Works MDWEQ5 now working on Pro Tools 2019
Dear All,
I thought I would post this for you.
I had problems with Massenburg eq not working on Protools 2019 and windows 10 pro.
Massenburg have just recently released new beta versions via Avid and it works just fine now.
Below are links to the new beta versions
http://resources.avid.com/SupportFil..._5_2_1_r11.dmg
http://resources.avid.com/SupportFil...X_5_2_1r11.zip
http://resources.avid.com/SupportFil...e_5_2_1r11.zip
Hope this helps.
Craig
  #74
Old 06-14-2019, 08:35 PM
jsvalmont jsvalmont is offline
Beta version crashed Pro Tools the first time I tried using it. MacOSX 10.13.6, iMac Pro, Avid HDX2, Pro Tools 2019.5.0
  #75
Old 06-18-2019, 01:10 PM
abc1mce2's Avatar
abc1mce2 abc1mce2 is offline
The beta version is working fine on my system, thanks.
What is more relaxing than Music?
Pro Tools Carbon for macOS 12.7.4
My HDX for Windows11.
Gigabyte Z490 Vision D - BIOS F21b
Intel Core I9 10850K Windows11 / macOS 12.7.4 Hackintosh / 32GB of Rams
Avid Carbon/HDX 2024.3 Ultimate - 8x8x8 HD I/O - PT Dock - PT Control - Artist Mix (1)
Universal Audio Apollo Twin|X - UAD2 Pci-E and Satellite USB Octo v.11.0.1 - SOLO 610 - Twin-finity
Bricasti M7 (2)
Lexicon PCM96
Neumann KH805 - KH310
Yamaha NS-10M
Avantone Mixcubes
Grace Design M905
Etc, etc, etc.
  #76
Old 06-20-2019, 04:51 PM
abc1mce2's Avatar
The EQ Curve display doesn't work with this version. The plugin works and doesn't crash my system so at least it is now usable again .
Bricasti M7 (2)
Lexicon PCM96
Yamaha NS-10M
Avantone Mixcubes
Grace Design M905
Etc, etc, etc.
FS: Avid Massenburg Design Works MDW EQ5 AAX DSP/Native License Neil H Buy & Sell 0 08-08-2016 02:24 PM
Massenburg design works users, can you test 4 me crizdee Pro Tools TDM Systems (Mac) 12 02-05-2006 12:01 PM
Massenburg design works users, can you test 4 ZEUSS ProControl, Control|24, Command|8 3 01-28-2006 07:55 AM
Massenburg design works users, can you test 4 me sirpucho Pro Tools TDM Systems (Mac) 0 01-14-2006 11:42 AM
DIGI please design us a current config that works digi2000 Pro Tools TDM Systems (Win) 6 12-14-2001 09:24 AM
