Old 05-22-2013, 10:26 AM
steveos69 steveos69 is offline
Default Strike 1.5 Licence not detected [solved]
I installed Strike 1.5 successfully.
I am running Pro-Tools 10.3.5 on an iMac OSX 10.8.3
I use an M-Box Pro
I have a Strike 1.5 licence on my iLok
I have the latest iLok drivers.
When I start up Pro-Tools I get the error message:
"Pro-Tools could not load the following plug-ins because no valid authorization could be found"
So Strike will not work. I don't know why...
Old 05-22-2013, 10:58 AM
jeffro's Avatar
jeffro jeffro is offline
Default Re: Strike 1.5 Licence not detected
This explains the most likely cause. Let us know if it doesn't help.
Old 05-23-2013, 02:34 AM
That works! Thanks a mill :)
STRIKE content not found [solved] john1192 Virtual Instruments 34 11-04-2015 01:16 AM
Strike Plug-in not reading iLok Licence steveos69 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 12 04-20-2011 03:00 PM
Using my Strike Licence on a Stuidios ProTools setup CJO Virtual Instruments 6 06-09-2009 11:03 AM
Strike problem solved! cold school 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 06-02-2008 09:02 AM
