Old 04-27-2008, 11:16 PM
Eurydice Eurydice is offline
Default Error -1133
Hi everyone, I'm new here... I tried to search for this error but I got a huge batch of results none of which looked like what I need. I get this error when I try to start up my Pro Tools LE Mbox version 6.4. It says Design Hardware in use by another application. (-1133). Any help? I don't have any other applications running, except Firefox. I do also use Logic Pro 7.2 but if its not up shouldn't it leave the "design hardware" alone?
Thanks!
Old 04-28-2008, 06:59 AM
Phil Ogden Phil Ogden is offline
Default Re: Error -1133
You may be using a Mac/OS version that's incompatible with that version of Pro Tools. However, more information is needed before meaningful advice can be given. Specifically, a detailed spec for your Mac (model, OS, RAM etc). Check out this thread for guidance,
Help us help you
http://www.myspace.com/philogg
Old 04-30-2008, 06:45 PM
Thanks for the reply - here's the info. you mentioned - sorry, I should have put that in there...
I have a MacBook Pro, running OS X 10.4.11, 2.16 GHz Intel Core Duo, 1 GB M667 MHz RAM, and trying to run Pro Tools LE 6.4.
Do you see an issue with that combo?? I think the problem is more with another program as I was able to run this pro tools setup on this computer before.
Thanks again for your response, hopefully you have an idea how to help.
- E
Old 04-30-2008, 07:45 PM
your one guy your one guy is offline
you need at least pro tools version 7.0 for intel macs
Old 05-01-2008, 05:30 AM
PT 7.1.1 to be precise. See the 'red' compatibility link above.
Error -1133 in PT 8.0.3.250 LE Wire57 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 12-04-2017 04:47 AM
Error (-1133) edgar1986 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 12-24-2006 09:47 AM
Help with (-1133) error!! Renouf 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 06-25-2005 10:56 AM
Help!!! Please Error -1133 when trying to use besoyan 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 05-18-2005 11:51 AM
Still getting 1133 error.. drthfdr 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 03-30-2004 11:36 AM
