Old 04-12-2018, 10:26 AM
Default Re: Delay Compensation on AUX tracks - automatic
Originally Posted by sdmaas View Post
Any light on this subject? Figure out the problem? I am getting 4146 samples of delay on ANY aux track now for some stupid reason. I am freaking out
start by making all aux sends inactive. If that changes the ADC value, then its a routing issue
Old 07-21-2020, 03:35 PM
DAVE24 DAVE24 is offline
I know this is old, but there has never been an answer to this. I'm using an Aux track to track into an audio track. (I'm doing it to have a small amount of in the box compression going into PT) I hear my self perfect on the headphones when talking into mic, no delay. The issue is when I play back the signal recorded, it's .125 secs pushed back, so it's coming in a bit delayed. Does everything that gets routed into an AUX track get delayed, even if there are no plugs?
Old 07-21-2020, 05:29 PM
I'm not following you routing entirely, or what you are trying to do with compression or why... but... my first guess is this is a split buffer/playback buffer effect.
The split IO buffer in Pro Tools has been explained lots on DUC. Including way back around the days of Pro Tools 11 when it was introduced. If a path is not in an actual external IO path the buffer is 1024 or 2048 samples depending on the sample rate.
Maximum Automatic Delay Compensation HDX corp Pro Tools 10 4 01-20-2012 04:19 AM
Automatic Delay Compensation? Dax Xenos Pro Tools 9 15 06-06-2011 06:21 PM
Automatic Delay Compensation alfadog Pro Tools M-Powered (Win) 1 04-08-2006 07:53 PM
Automatic Delay Compensation stakeoutstudios 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 12-28-2005 01:02 PM
Automatic Delay Compensation slangification Pro Tools TDM Systems (Mac) 5 04-28-2004 11:02 AM
