  #31
Old 09-23-2020, 02:05 AM
martthie_08 martthie_08 is offline
Default Re: 2020.9 stability...
ok, I found the culprit of the spinning beachballs:
AVID Link reinstalled after the update..
once I removed it everything went back to smooth sailing!!
  #32
Old 09-23-2020, 02:42 AM
Emi's Avatar
Emi Emi is offline
That´s the first thing I do after updating.
Mac Mini M1 | Mac OS 12.6.1 Monterey | Avid Carbon + 2x Carbon Pre | Pro Tools Studio 2024.3
  #33
Old 09-23-2020, 07:15 AM
thebeatless thebeatless is offline
I'm also having issues with RX 7 and 8. I'm sorry you're dealing with it too, but happy to hear that I'm not alone! I've gone back and forth with support for over a month, and I still haven't found a solution. They made it sound like I was the only one. This is on two of my 3 systems! It works perfectly on my windows system, but not on my macbook pro. I also recently "upgraded" to a 7.1 mac pro, and it has the same issue. Sometimes it works, usually it doesn't. I can usually at least open up an audiosuite RX plugin after opening a session with all plugins inactive, but sometimes that crashes too. If anyone finds a fix for this, please let us know! It's a HUGE workflow killer for me, and I'm furious about it!
I'm also having an issue with Sonnox Drum Gate. I can't open the plugin window during playback without getting a show stopping CPU error. If I forget and click to open it while playing, I get a cpu error, and then cannot playback the session until I quit and relaunch pro tools. Again... Fine on windows, but this is 100% reproducible on the new mac "pro".
Begin rant: I'm pretty furious that the insanely expensive mac "pro" can't hang with the CPU power of my i9 9900k windows machine. Still trying to decide if I want to keep the mac because of it's lack of power when using pro tools, and stability issues mentioned above. I only use it for pro tools, and feel like these machines seem to be better suited for other applications. Sadly, iMessage is the one thing that keeps me on mac. Crazy that something as simple as a messaging platform can get it's claws in so deep! Why isn't there a slightly larger mac mini/screen-less iMac with an i9?
  #34
Old 09-23-2020, 07:42 AM
Sonnox Drum Gate working just fine, without the mentioned behaviour, on a 2013 Mac Pro so it must be some other compatibility issue. For troubleshooting, move all your plugins to unused folder except Sonnox Drum Gate and try again.
  #35
Old 09-23-2020, 08:10 AM
DontLetMeDrown DontLetMeDrown is offline
OT, but this shouldn’t be a surprise in 2020. Should’ve been apparent from the system specs, right? Macs have been behind here for the past decade but Apple still charges very high prices and apparently people are willing to pay for it.
  #36
Old 09-23-2020, 11:16 AM
orvillej orvillej is offline
How do I uninstall Avid Link? I've gotten rid of it before but in both Application Support and under Avid in my App file there are folders for Avid Link but no uninstaller in either.
using PT 2023.9, 24' iMac M1 16GB RAM, Ventura 13.6.1, Apollo Twin interface
  #37
Old 09-23-2020, 11:17 AM
Uninstaller should be installed with it
  #38
Old 09-23-2020, 11:25 AM
StudioRhythm StudioRhythm is offline
I'm also having issues with RX 7 and 8....
Just saw this and I'm 99% sure I have your answer. I upgraded to a Mac Pro 7,1 this spring and immediately had the same problem with RX7 AudioSuite plugins crashing Pro Tools. After nearly a week of experimenting I figured out what was going on:
If you have any instances of Oxford Drum Gate in your session, and you have a version of ODG higher than version 1.0 installed, you won't be able to open an RX AudioSuite plugin without an instant forced quit of Pro Tools.
If I remember correctly, you can even open a session that has an instance of Oxford Drum Gate, close that session, open any number of new sessions that don't use ODG, and you'll still get an unexpected quit when you try to open an RX AudioSuite plugin. Just opening one session with an instance of ODG seems to put PT in the "ready-to-crash" state.
Oxford Drum Gate version 1.0 works fine though. Unfortunately the settings aren't compatible with later versions in Pro Tools though, at least for automation, so you'll lose any plugin automation going between versions.
This is on a Mac Pro 7,1 running Catalina 15.3 and Pro Tools 2020.5 and 2020.9.
I reported the issue to both Sonnox and iZotope in late May/early June and heard back from tech support at both companies, but I'm sure additional reports wouldn't hurt.
www.studiorhythm.com
  #39
Old 09-23-2020, 11:48 AM
originalscottyg originalscottyg is online now
Look for the Avid Uninstaller folder in the Applications folder. It disappears once Avid Link and Cloud Client Services have been uninstalled.
Scott Gatteño
  #40
Old 09-23-2020, 11:49 AM
Does not disappear here. What system are you using?
Pro Tools 2020.5/2020.3 Compatibility with Catalina 10.15.4? derrickhou macOS 4 07-26-2020 07:46 AM
Avid Control App Rollback (2020.5 to 2020.3) budster Avid S1, S3, Dock and Control App 2 06-09-2020 11:01 AM
2020.3 and OS10.13 - Initial signs of stability..? Paul Winstanley macOS 17 04-23-2020 06:54 AM
Pro Tools (2020.3) on MacBook Air 2020 compatibility pellekuipers Pro Tools 2020 1 04-04-2020 08:01 AM
New Avid Link 2020.1 - launched today 1/16/2020 marianna Licensing & Accounts 8 01-16-2020 11:43 PM
