When I Bounce To Disk (from the File menu, or by right-clicking on the track), the bounced file is -1.1dB lower than the track I'm bouncing. The track has no automation, the volume is at 0dB, no plugins on inserts, etc.
Is anyone else getting this?
Pro Tools Ultimate 2020.9.1 OS X 10.15.7 (Catalina) Mac Pro (Late 2013) 2.5 GHz 12-core Intel Xeon E5 32GB of 1866MHz DDR3 RAM 1Tb SSD hard drive Antelope Orion 32+ UAD-2 Satellite OCTO Core (thunderbolt) |
![]() Quote:
Hi, Is your master fader set to zero? Any plugins on the master bus? And you do mean bounce? not export file! Chris
Yes.
No. File->Bounce To->Disk and... Right Click on Track->Bounce same result Maybe it's a bug?
Did you try export file and see if the result is different as a test? I understand that this is not what you ultimately want to do.
How is the track level being measured, and how is the bounced file being measured? Are these peak values, RMS, LUFS?
David J. Finnamore Nyquist was right. PT 2020.11.0 Ultimate | Omni | macOS Mojave PT 2020.9.1 | Saffire Pro 40 | Win10 |
Also check the 'bounce source' in the bounce dialogue box..
That's where my head went as well. Feels like a discrepancy somewhere.
It could be related to the pan law, in case you are bouncing a mono track routed to the stereo master/out
Avid HDX - Avid HD I/O 16x16 Analog - Pro Tools Ultimate 2020.11 - Cubase Pro 10 Mac Pro 5.1 quadcore 2.8 32GB Ram - Mac OS 10.13.6 |
+1
Or a rogue yellow (trim) fader inadvertently down 1dB?
PT12 on Windows 7 Pro- no multiple bounce source tracks in Bounce To Disk window? | js_nyc | Pro Tools 12 | 6 | 04-21-2016 04:37 PM |
Bounce to Disk issues and bounce to direct show error. | SeattleHank | Windows | 7 | 01-01-2014 01:41 PM |
Bounce mix - import into new session, bounce again - does this affect quality? | Mattitude | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 06-13-2011 06:14 PM |
adding or subtracting time in session | keithaska | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 11-19-2010 08:29 AM |
5.1 wont bounce. Says "bounce handler cant keep up try convert after bounce...." | Trash Man | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 9 | 05-21-2001 09:28 PM |
