Old 09-17-2019, 09:20 AM
lesbrunn lesbrunn is offline
Default Volume View Anomaly
Hey guys,
I haven't been around here for some time, but it's still the best place to come to when having problems in PT! This is a super community!
I'm on PT 12.8.1, using Windows 10 1903. I was working on some volume automation on a mix, but when I got to a vocal track, I dicovered the volume line in the volume view does not correspond with the fader position in the mixer. The fader is at -7dB, but the volume line is cranked all the way to +12.
There is no volume automation on the track. Sliding the fader down lowers the volume line, but when I move back up to -7 the volume line again hits the top.
Has anyone else experienced this? I'm assuming this is a corrupt session, and am considering importing all the tracks into a fresh session. Any help will be much appreciated.
Thanks!
X99 | i7 5820 | 64GB GSkill DDR4 | Nvidia GTX 950 | Samsung 950 Pro 256GB | Kingston 120GB SSD | Samsung 850 EVO 1TB | Samsung MZ7PD256HAFV-000H7 SSD 256GB | WD Black 1TB x2 | G-Drive 4TB | Audient ID14 | PT12.8.1 | Windows 10 Pro
Old 09-17-2019, 07:09 PM
Led Led is offline
Default Re: Volume View Anomaly
You could try highlighting the whole track and hitting delete to reset the volume auto in case there is some sort of breakpoint in there you aren't seeing..?
Andy Evans
Sound Designer/Composer/Mixer
Melbourne, Australia
www.mud.net.au
Old 09-17-2019, 09:29 PM
Thanks. I did that. There was no automation on the track. The fader was moving freely without bouncing back, while the volume line was somewhere else. It could be controlled by the fader, but there was a huge level offset.
I've solved the problem, though. After spending a long time importing 81 tracks one after the other, it was still the same. I eventually created a new audio track and moved the waveform, inserts and sends to it from the old track. That did the trick.
After all these years Avid should find a more elegant way to repair corrupt sessions! I don't believe any other DAW requires you to import tracks one at a time into a new session. It's absolutely tedious and primitive (and it didn't even work in this particular case)
Old 09-18-2019, 01:06 AM
Led Led is offline
sounds like a drag to work around. Dod you have any backup sessions you could try?
Andy Evans
www.mud.net.au
Waveform View And Volume GTBannah Pro Tools 2018 12 03-01-2018 03:12 PM
Volume view weirdness Bookerv12 Pro Tools HDX & HD Native Systems (Mac) 3 04-08-2016 06:18 PM
Quick key for changing edit view to volume view in track? postman56 Pro Tools TDM Systems (Mac) 4 11-30-2007 10:56 AM
Volume view edits as relative steve at Your Heaven Pro Tools TDM Systems (Win) 7 11-29-2004 05:14 PM
Waveform --> Volume view ??? Brian Kingman General Discussion 2 11-12-2000 04:46 AM
