Go Back   Avid Pro Audio Community > Pro Tools Hardware > FireWire and USB Audio Interfaces (Win)
Old 09-13-2019, 07:58 AM
Studio66 Studio66 is offline
Default 003 Main Volume Pot
Loving my 003 but the main volume pot has become scratchy....as they do.
Anyone replaced one successfully?
Still useable since it only “scratches” when you turn it abruptly but would still be interested in fixing it up...if possible.
Thanks!
Old 09-13-2019, 01:26 PM
Default Re: 003 Main Volume Pot
The pot is probably available(if you can figure out the value and taper) from Digikey. Having said that, you might also be able to get the part from an Avid-approved service shop(like allproelectronics.com based in Nashville, TN).
Another option is to not use the knob on the 003 and add a monitor/source selector to your setup. I've been using a Presonus Central Station for years and can't imagine not having all that functionality. The Central Station does have a small issue(design flaw?) in that whenever you turn the volume down to the bottom 20%, the image shifts off the the right(verified on at least 5 of them in 3 studios), but it happens at a volume that nobody would be paying attention to. Tops on my shopping list right now(as a replacement) is the Audient Nero($499).
No doubt you are wondering if another piece of hardware is worth the money, so here's why I can't live without it(BTW, I also am running a 003R)
#1-I can switch between Pro Tools audio(on RCA SPDIF), computer audio(on lightpipe SPDIF), computer 2 audio(second PC for non-audio stuff), iPhone(via mini TRS cable hanging out of the rack) and a second set of outputs from PT(long story, but something I need).
#2-I can switch between 2 sets of speakers, with or without a subwoofer. Food for thought
Old 09-13-2019, 07:08 PM
I also was looking at the Nero....
I have a Steinberg UR824 that I use when messing around in Cubase and the Nero would be great for using both with the same set of monitors.
It would also solve the problem of my sub par headphone amp in the UR
Excellent advice....Thanks
Enabling Trim Automation for Main Volume only marvschlom ICON & C|24 2 03-07-2013 09:56 AM
Main volume knob...is it just like the 002R? Gothboy ICON & C|24 1 05-09-2010 07:29 PM
Main volume monitor? LarsKatz 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 01-30-2010 10:19 PM
C24 Main out Volume.... Table Syrup Records ICON & C|24 2 07-19-2007 06:37 AM
Main Volume Level Kipsey Tips & Tricks 0 05-01-2003 06:38 PM
