Go Back   Avid Pro Audio Community > Pro Tools Software > Pro Tools 2018
Old 08-18-2018, 08:32 AM
fourthtunz fourthtunz is offline
Default 2018.7 better than 12.8.3 on a mac?
Thinking about upgrading from 12.8.3 to 2018.7 on my 2012 MacBook pro
I7 quad 2.7 16 gigs ram on Mac OS sierra 10.12.6...
Did you notice a performance boost when going to 2018.7 ?
Have you found that most of the plugins are compatible?
Id like to keep 12.8.3 on the same machine
Do I need to rename 12.8.3 to something else to keep it from being upgraded?
thanks!
Old 08-18-2018, 08:57 AM
lae777 lae777 is offline
Default Re: 2018.7 better than 12.8.3 on a mac?
I haven't noticed much of a performance boost with 2018.7 but it is very stable, although I am on High Sierra, not Sierra.
I guess stability is a kind of performance boost but maybe not the kind you were necessarily after.
I've had no problems with plug ins.
The Pro Tools app in your Applications folder will just be called "Pro Tools" unless you've renamed it.
If not then rename it "Pro Tools 12.8.3" and install 2018.7.
2018.7 will then be in your applications folder and will be called "Pro Tools".
It will then behave as usual when you use your chosen method to launch Pro Tools.
5,1 Mac Pro, 3.46 GHz Six Core Xeon, 48gb ram, Pro Tools Ultimate 2019.5, HD Native card, Avid 96io interface, Avid 192io, Intensity Pro video card, Radeon HD 7970 graphics card, Mac OS X 10.13.6
Old 08-18-2018, 09:22 AM
No noticeable performance change from 12.8, but stable and working fine.
Dunno about the wisdom of having both versions on your machine - if you're doing it because you're afraid of the upgrade then you should really have at least one bootable clone of your system drive (you should have that regardless).
http://www.richbreen.com
MacPro 5,1 Dual Hex, OS 10.12.6, PT 2018 HDX, Avid HD I/Os and Metric Halo ULN8, Avid C24.
Old 08-18-2018, 11:59 AM
zion's Avatar
zion zion is offline
Is more stable at low latencey and has better CPU usage on my system.
Pro Tools 2019.6 | Studio One 4.5 Pro | Pro Tools 12.5.2 HD | Apollo X8 | UAD Octo Sat | UAD Quad Sat | Mac Mini 2018 i7 | 16GB Ram | 512GB SSD | Mojave 10.14.3 | OWC ThunderBay 4 | Drives’s Samsung EVO 860 + 840 + Crucial M4 SSD | Plugins | UAD, Softube, Waves, Nugen, Fabfilter, SSL, Lexicon, Eastwest, NI KOMP 9 ULT, PSP, IKMulti, Antares, Celemony, Slate Dig, etc | AKAI Pro Adv 61 | PreSonus Fader Port | Townsend Labs Sphere L22
Old 08-19-2018, 08:07 AM
Thanks for the help, be nice to try it out and not have to commit to it.
Old 08-19-2018, 08:08 AM
Heh I read your post and backed up!
Going to download and try out 2018 today, thanks!
Old 08-20-2018, 09:05 AM
As long as both versions of Pro Tools are compatible with the macOS, there shouldn't be a problem. The only real issue would be HD Driver versions if you are using HD hardware. I use Pete Gates' PT Prefs program to backup my prefs, and I always make a redundant copy of a particular PT version's prefs when I co-install, so I don't have to rebuild prefs if I end up using the previous version. After that, it's just a matter of renaming the current PT version and installing the new one. For full disclosure, I always uninstall App Manager and Cloud Services right away after every install, so I can't speak to how those items might affect co-installs.
Of course, bootable clone OS backups are necessary and a good idea no matter what. I use Carbon Copy Cloner for this.
Scott Gatteño
Yessian
Old 08-20-2018, 09:32 AM
JFreak's Avatar
JFreak JFreak is offline
2nd for CCC
Janne
Old 08-20-2018, 12:47 PM
TNM TNM is offline
thanks!
2018.7 on 10.12.6 is by far the best pro tools I have ever used in my entire life. I recommend it specifically FOR performance even if you don't need the new features. Haven't had any plugin issues yet.
I'm on the 2014 model quad 2.8 macbook pro, not much more powerful than yours (around 10% clock for clock from ivy bridge to haswell), and i can finally work in 64 buffer in PT for the first time ever (at 44K) or 128 buffer at 96K instead of 256 buffer.
All cores loaded evenly. I highly recommend this release.
1) iMac Pro 3.2ghz 8 Core, 64GB Ram, 2TB SSD, OS 10.13.6, Caldigit TS3+ Dock, Startech USB-C raid enclosure w/ Crucial MX500 1TB x2, 1TB SSD-R G Tech x 2, Samsung 860 Pro 512gb Audio Drive in USB C Enclosure, TBolt Apollo 8 x 2, TI2 Desktop, MoxF6, tons more midi synths, PT 2018.7/Cubase9.5.
2) MBP 2.8ghz i7 quad, 16GB ram, 1TB SSD, OS 10.12.6, PT 2018.7, Logic 10.4.1,Internal Sound, TBolt SSD 512GB.
Old 08-21-2018, 07:18 AM
Wow! The 64 buffer is a big deal!
Thats good to know!
I put it on my machine along with 12.8.3..
Thanks for the help!
Macbook Pro 2018 w/ UAD Apollo 8p and PT 2018.7 Performance Issues Dudiester Pro Tools 2018 5 08-12-2018 08:33 AM
OS 10.13.5 - will PT 2018.4 or .5 work well or stay with 2018.13? blankpro Pro Tools 2018 4 07-11-2018 07:22 PM
Pro Tools 2018.3 / 2018.4 crashing when switching window configurations matthewmkb macOS 0 06-27-2018 06:33 AM
Upgrading from 2018.1 to 2018.3 with Application Manager lm183902 Pro Tools 2018 2 03-19-2018 04:41 PM
Xpand!2 2018 & Air Instruments 2018 lgreen100 Pro Tools 2018 16 02-15-2018 05:01 PM
