Old 08-23-2016, 06:50 AM
princeplanet princeplanet is offline
Default Buffer problem with 2015 macbook pro
Have put a deposit on a used 2015 macbook pro i7 (2.2 ghz) 256 SSD 16 GB DDRRAM. But, upon reading about it's suitability for ProTools use, seems there are CPU issues on low buffer settings. Is there a fix for this? Should I get an older machine? Was thinking of using it with PT 10 HD.
There was another MBP from 2011 ( i7 - 8GB DDR3 - 500gB sata drive)
Will this work just as well? In which way will it be less efficient (apart from SSD speed)?
Cheers!
Old 08-23-2016, 07:18 AM
YYR123's Avatar
YYR123 YYR123 is offline
Default Re: Buffer problem with 2015 macbook pro
By as much as you can afford....
Generally the higher clock speed is better, and most prefer cores over clock.....
ie a 6 core is better than a 4.
SSD 's are always doable after the purchase.....
I would "Assume" a 2015 MBP would be a safer investment....than a 2011 just b/c of the different architecture of the components.....but I don't specifically know about either of those MBP's
Daniel
Old 08-23-2016, 08:07 AM
But can the newer MBP's be pulled apart for mods? I don't think so.
Jack
QAPLA!
Old 08-23-2016, 08:08 AM
YYR123's Avatar
Check OWC and or ifixit.com to be sure, idk
Daniel
MacBook Pro (2015) & Digi002 somefinn FireWire and USB Audio Interfaces (Mac) 10 03-25-2016 03:59 PM
Mid-2015 Macbook 15 inch Fan Noise traveler322 macOS 2 12-09-2015 10:50 PM
Has anyone tried out the 2015 Macbook? KrisHeinold General Discussion 6 09-25-2015 10:21 AM
mbox 2 pro/macbook pro-6085 buffer problem.need serious help goodbyeboy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 7 08-09-2007 09:32 AM
harware buffer size problem MacBook pro Edson 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 01-12-2007 08:08 AM
