Old 10-07-2015, 12:27 AM
traveler322 traveler322 is offline
Default Mid-2015 Macbook 15 inch Fan Noise
Hello,
I just recently picked up a new macbook to run pro tools on. I'm currently on version 12.2.1 with OS X 10.10.4. Whenever I do anything in pro tools when I'm connected to my external monitor the fans get really loud (even with the just the laptop in use the computer heats up a lot in all of these circumstances). I have the GPU on this computer so I know that that could contribute to the heat but i'm not sure if that's the main problem. It doesn't matter if there are plug ins or not. Multi track recording, fans. Playback of just raw tracks, fans. I also use Logic X and even after a full mix with he same setup of interfaces and external monitor my computer is silent. I know they are made by separate companies and one is most likely more fine tuned for the computer but it seems like a huge difference. Is this normal? Does anyone here have this model and can tell me how it runs on their computer? Thanks for any help!
Old 12-05-2015, 12:21 AM
Thenewexhibit Thenewexhibit is offline
Default Re: Mid-2015 Macbook 15 inch Fan Noise
Originally Posted by traveler322 View Post
Hello,
I'd love to hear someone chime in on this. I have a mid 2014, and it's an absolute beast in terms of specs, yet, my computer fans go ape $h*t with the session showing system usage of around 28-30%. Doesn't seem like that should happen, or no?
Old 12-09-2015, 10:50 PM
xylie6 xylie6 is offline
I use the SMC fan control application. It gives you control over the fan speed and also shows the temp. Free to download and use.
Has anyone tried out the 2015 Macbook? KrisHeinold General Discussion 6 09-25-2015 10:21 AM
MacBook 13 inch, i7, 2.9 ghz, 8gb JustGotPaid macOS 4 01-17-2013 11:03 AM
15 or 17 inch New Macbook Pro? cary chilton macOS 14 03-23-2011 02:15 PM
Which is better? (New) MacBook Pro 15 inch or 17 inch Hookshot 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 13 07-21-2009 09:07 PM
They're Here! MacBook Pro - 17-inch coolcat 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 04-24-2006 02:20 PM
