Old 05-11-2012, 05:44 AM
musikrolf musikrolf is offline
Default Lost connection to Mix and Control
I have a PC with Windows 7 X64 connected to MC Mix and MC Control, since yesterday. Everything went smooth, but from yesterday on the devices appear no longer in the EU Control panel. I see the devices in my LAN, I can make a ping from the hosts to the devives, working. But in no way I am able to connect. I swear, I did not change the configuration of the PC.
Any help?
Rolf
PS: The last thing I checked when they were alive, was for firmware update. But they respond they'd be up to date.
Old 05-14-2012, 10:25 AM
rcutz rcutz is offline
Default Re: Lost connection to Mix and Control
I`m having the same issue here. More than one year of initerrupt use of a mix and control and today, from nothing they start to lost communication.
In my case it is a intermitent problem. I can do the same check as you, but they "lock" to pro tools, then unclock... then lock again.
Also I have the firmware uptodate...
mac os x 10.6.7.
PT HD 10
HD Native.
Ricardo Cutz
Re-recording mixer/sound editor supervisor.
Http://106db.com.br
Old 05-15-2012, 04:10 PM
klyg klyg is offline
Angry Re: Lost connection to Mix and Control
Same problems here, both on Mac and win7. Tried static ip, same problems, tried to trash Mac preferences, tried adding a dedicated router ....., no way. Lost of Eucon specially when running more 10 tracks or more. Eucon weakness = Network instability. Please AVID improve Eucon.
tried Avid suggestions : update last firmware / drivers (of course I did it, Avid !)
Connect mc mix and control direct to mac ? (how can then I use Eucon on the network with other mac / win7 workstation ?) isn't Eucon supposed be "applications ware" ?
All that is unacceptable and not "PRO" at all !
I am musician, not network / computer administrator !
Cheers !
Old 05-15-2012, 04:31 PM
Hi, after an entire day fighting against it, I re-install the PT 10 and the EUCON.
And it works... I also take it out to the router using a dedicated switch.
but it come from now where and now is gone...
Ricardo Cutz
Http://106db.com.br
Old 05-16-2012, 07:33 PM
robertg robertg is offline
the problem probably lies in the protools implementation and not the physical networking hardware, I don't have this problems at all using logic.
Old 05-16-2012, 10:34 PM
Cool Re: Lost connection to Mix and Control
True logic is more stable,
But I have the same problems using Logic 9,
it's Eucon Level
Please AVID improve Eucon's code
Cheers !
Old 05-20-2012, 08:12 PM
Bluebeep Bluebeep is offline
Good to hear about it maybe being a ProTools thing (I'm a Logic user). I've been considering buying these devices and becoming a little turned off reading about connectivity problems all over.
Thanks for clearing it up a bit.
Maybe others can verify? If you can detail your experiences, you can probably help figure out the exact setup that causes the issue and maybe Avid makes a fix for it?
Old 05-23-2012, 07:00 AM
lberrios1962 lberrios1962 is offline
Guys I had the same problems with Protools 10 and Samplitude Pro X. At the end I returned the Control, it wasnt worthy. It's not just Protools, Eucon is not stable at all.
Old 05-23-2012, 07:14 AM
chris-euphonix chris-euphonix is offline
It's rock solid here (with Mac running Logic).
FWIW my Artist units have the default configuration ("use DHCP"), and the DHCP server on my router is using static reservations, so each surface always gets the same IP address.
Old 05-23-2012, 07:34 AM
Hi Chris,
How many units o you have ?
Because even with static reservation, my control + 2 mix keep on losing connection, but with 1 control and 1 mix, no problem...And disconnections happens only with osx lion, not with win7x64...
Cheers !
Lost connection Stig Eliassen ICON & C|24 8 03-13-2012 03:19 PM
Anyone running 64bit with MC Control or Mix? Connection keeps getting lost Cyndicate Artist Series 1 03-18-2011 10:06 AM
Lost Connection 6figgas 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 08-16-2006 12:09 AM
Digi 002 lost connection Keniko 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 08-19-2005 01:55 PM
HUI lost connection after restart Fokke van Saane Pro Tools TDM Systems (Mac) 5 10-04-2003 03:19 AM
