Old 11-12-2011, 08:55 AM
Stig Eliassen's Avatar
Default Lost connection
Guys, I've lost the ethernet connection between the G5, network hub and the console, and I can't get it back. I've unplugged everything, power-cycled everything and tried to enable ethernet again in the peripherals dialog. No dice.
Old 11-12-2011, 08:59 AM
Default Re: Lost connection
I have Vienna Ensemble Pro installed on both the G5 and the Westmere, and that setup works, and everything goes through the HP Procurve network hub.
Old 11-12-2011, 10:21 AM
Yeah, power-cycled everything except the console! Talk about performing under pressure. (note to self: calm down)
The upside is that I had to work a couple hours without the console, and it was plain torture. Slow, slow, slow. I appreciate the investment that much more now.
Old 11-13-2011, 07:43 AM
Chris Lambrechts's Avatar
Chris Lambrechts Chris Lambrechts is offline
You ok now Stig ? Everything up and running again ?
Chris
Chris Lambrechts
Applications Specialist- Live Sound
Old 11-13-2011, 08:39 AM
Default
Chris
Yeah, I'm all good now. Thanks.
Old 03-13-2012, 12:27 PM
musclepants musclepants is offline
Hey guys,
I have the same problem. I upgraded to PT 10.0.0 & lost the ethernet connection to the ICON. I've power cycled everything, including the ethernet hub, but the main & fader unit on the ICON will still not show up on the peripherals menu in PT.
Any suggestions?
Thanks.
Mac Pro
OSX 10.6.8
Original ICON
XMON
2 x 96 i/o
Old 03-13-2012, 01:17 PM
Soundtrack Soundtrack is offline
Not sure or this could help you, but do you check the right ethernet socket under "peripherals" , because the powermac has 2 sockets..??
Grz,
Louis
Old 03-13-2012, 01:35 PM
Louis,
Thanks for the response. Yes, I did check the correct ethernet port. I've tried going into both ethernet ports, with & without the ethernet hub.
Old 03-13-2012, 03:19 PM
I lose connection about once a month or so, and a power-cycle fixes it every time. That is, I have a routine that I always follow. Probably not necessary, but it works for me:
  1. Peripherals > Disable ethernet controllers
  2. Quit PT, and power-cycle the D-Command
  3. Reboot the G5
  4. Launch PT
  5. Peripherals > Enable ethernet controllers
  6. All good again!
Digi 002 Lost connection-Help Please! Bantom 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 05-31-2012 12:29 PM
Lost connection to Mix and Control musikrolf Artist Series 9 05-23-2012 07:34 AM
Lost MIDI connection manyrains Virtual Instruments 3 07-06-2008 08:38 PM
Lost Connection 6figgas 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 08-16-2006 12:09 AM
Digi 002 lost connection Keniko 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 08-19-2005 01:55 PM
