Old 02-27-2012, 05:31 PM
Winnorf Winnorf is offline
Default Re: Marking End Point of Song for Bounce?
I am new at this but I need to make the end and out points follow the highlighted clip parts. It was doing that at one time but now preferences have changed.
Old 02-28-2012, 03:38 AM
Stig Eliassen's Avatar
Shift+/ (numpad) to link timeline and edit selection.
Old 02-28-2012, 05:32 AM
PD-John PD-John is offline
Originally Posted by DrFord View Post
I actually found a fun trick I use on every session as part of my new session template. I create a mono audio track and set the voice to nothing. So it doesn't use any resources. Or just make it inactive. Then I highlight roughly 5 minutes of audio from session start, and consolidate selection. Shift + Option + 3. You should have a file with nothing in it that doesn't playback. That is then saved to my template.
Now I typically start all my songs at bar #9 so that if I need to do an intro or anything I have some blank space to work with (I don't use pre 0 tape out of habit) and then I will use the trim tool to adjust the start and end length of the blank audio file to form the bounds of my song. This I then name "Guide Track" and it serves as a nice way to quickly double click the blank audio file at any place in the song and it will begin from wherever you set it.
Explaining this takes longer and seems more complicated than actually using it. I always mix with my Master Fader far left, followed by my effect sends. So I drag the Guide Track all the way to the left beyond the master fader so I it sits at the very top underneath the "Universe View" for easy access.
This also allows you to scroll off the end of the song easily and add or remove your selection with the trim tool to cath the perfect amount of reverb tail.
There's my trick! Works like a charm. When you are ready to bounce you just double click the region and hit bounce.
That's a great method! I usually make a memory location for the selection, but I see how this could be more beneficial.
Old 09-08-2019, 03:02 AM
danyg danyg is offline
old thread but I have the same question (PT12 and Commit)
I also use a marker or audio file as a solution but when I use the function "commit track" I get 30 seconds of empty audio and the end of the track.... there must be something like a right locator to stop the bounce/commit
No?
Mac Pro 12 core 3.46Ghz - 64 Gb ram - SSD 500 Gb - HD1 2T - HD2 2T - OS 10.10. - Mac Book Pro retina- OS 10.10. - SSL Alphalink convertor - Pro Tools 12 native - SSL Matrix console - Logic Pro X
Old 09-08-2019, 03:53 AM
JFreak's Avatar
JFreak JFreak is online now
I always select the part of the timeline I want to bounce, but maybe I'm oldskool...
Janne
  #16
Old 09-08-2019, 03:57 AM
Sardi Sardi is offline
Me too.
I thought that’s what everyone did.
  #17
Old 09-08-2019, 04:04 AM
yeah, but with commit you have the choice between "track" and "selection"
so what is the "track" option for if it doesn't bounce the the correct song length. With "selection" it's correct.
song won't play from insertion point davidp158 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 9 12-29-2012 04:52 PM
Marking an end point for scoring and printing trin Tips & Tricks 2 06-15-2010 01:49 PM
New Song start point? tonyridino 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 03-14-2010 11:24 PM
Changing the end of song point BlueThursday 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 03-09-2009 05:47 PM
MARKING AND END POINT IN A PT 6 SESSION Johnny916 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 04-23-2004 11:29 AM
