Problem with real time MIDI properties
WHen attempting to use Real Time MIDI duration quantize I get these errors:
Time Type mismatch occured in "Time_Typed.ccp" line 314 I click OK then I get Assertion in "Protools.ccp", line 1516 I click OK and these same warning dialogues come up again for three or four times, like a loop. Suddenly the instrument track (w/Spectrasonics Trilogy bass) will lose all MIDI data. <poof... gone> The only distinguishing features of this session is that it is a bit VI and RTAS plug heavy... (2) Trilogy, Ivory pno (set at 28 voices), (2) Atmosphere, Sampletank 2SE (1 channel), IndigoV40 (TDM), Xpand! Am also using Waves Tune L on four tracks. Have had no problems with playback, however. Settings in playback engine are H/W Buffer 512, 2 RTAS processors at 90%, 64 voice 2 DSP mixer, Long delay compensation engine enabled, DAE buffer Level 4. Any ideas anyone? Thanks in advance! PT Accel|3, G5 dual 2.0 w/2.5GB RAM, PT 7.1cs10, OS 10.4.6 |
Midi Export -> "Apply Real Time Properties" Question | Sparky1 | macOS | 2 | 12-12-2020 04:54 AM |
midi real time properties issues | End Over End | Windows | 0 | 03-14-2014 11:38 AM |
Question about midi real-time properties | mahag | macOS | 2 | 05-05-2013 11:54 AM |
Real Time Properties in MIDI w/ regard to Playlists | Kourquie | Pro Tools TDM Systems (Mac) | 11 | 04-03-2009 04:07 PM |
MIDI Notes disappear when real time properties enabled | BGee | Pro Tools TDM Systems (Mac) | 5 | 08-11-2007 09:42 AM |
