  #21
Old 10-23-2015, 09:43 PM
soul's Avatar
soul soul is offline
Default Re: Sample Rate Mismatch! (clock 44.1, PT 48)
Consolidate each track.
Export WAV files from clip list.
Make a new session.
Import WAV files to new session.
PT HD4 10.3.8 / Mac OS 10.8.2 / Intel Core i7 3.4Ghz / Heat / X-Form / McDSP / Eventide / Soundtoys / UAD-2 / Ableton Live 9 Suite / NI Komplete 12
  #22
Old 11-24-2015, 11:57 AM
Dark Pines Dark Pines is offline
I'm really confuzzled....
Session created at 48, clock at 44.1...
Creating a new 44.1 session and importing session data yields a 48k sounding print, and/or bounce.
That new 44.1 session plays incorrectly at 44.1 clock. It's pitched up like a 48 sample rate.
Tried SRC and non SRC session data import, with the exact same results.
I've exported 44.1 consolidated clips from:
48 session/44.1 clock
48 session/48 clock
44.1 session/48 clock
44.1 session/44.1 clock
Importing the different 44.1 exports into a 44.1 session, everything plays back at what sounds to be a 48k sample rate.
When importing the 44.1 audio into a new 48k session, tracks play correctly. But, anything printed or bounced at 44.1 still sounds 48k sample rate.
I've looked at and modified headers in Workspace AND in SoundHack....
NOTHING seems to matter... every time I print or bounce... I get incorrect sample rate... regardless of what it sounds like on playback within ProTools.
This is the only time I've had this glitch happen, and it really does seem like ProTools is experiencing a serious bug that needs to be fixed ASAP. I've imported session data without SRC and had the files all turn out fine... So, it's not making much sense as to what I'm doing wrong, if I'm really doing anything wrong.
If I can't correctly resample the tracks on import, nor export them from within ProTools, then it has to be an issue with 10HD, correct?
Could it be that the conversion just needs to be done on another machine because of some goofy session file corruption?
Mac, PT 10 TDM, HD3.....
Thanks for any advice or thoughts on how to cure this mess.
Max
  #23
Old 11-24-2015, 12:17 PM
acacia acacia is offline
Here's my .02
Everything that was suggested with importing session data with and without SRC, changing the SR in workspace... you name it. It did not work.
http://www.railjonrogut.com/HeaderInvestigator.htm
You'll need a PC but this works and it's fast.
Luke Rohwer
Acacia Recording & Production
www.acaciarecording.com
Luker[at]acaciarecording[dot]com
Studio 301-703-0035
sample rate mismatch problem? Kevin_28 Pro Tools 9 4 12-22-2010 11:18 PM
Sample Rate Mismatch... How to export files as regions after problem. Dizzi45Z Pro Tools TDM Systems (Mac) 2 04-24-2010 10:17 PM
Big Ben / PT sample rate mismatch zakco Pro Tools TDM Systems (Mac) 2 10-27-2007 06:36 PM
Pro Tools LE Sample Rate Mismatch Nag tcassel 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 03-20-2007 12:51 PM
sample rate mismatch with HD24 on whole session BuddySchaub 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 02-10-2004 12:53 PM
