Go Back   Avid Pro Audio Community > Other Products > Pro Tools Express on Windows
Old 03-17-2013, 08:04 AM
Spidey5150's Avatar
Spidey5150 Spidey5150 is offline
Default No virtual instruments for express
I'm a newbie here so bare with me. I have installed pro tools express and run the installer for the virtual instruments but don't see them in pro tools. Out of curriosity on the i lok I only received only one license for pro tools express. Should there have been one for the virtual instruments as well? And if so how do I go about getting it?
Thanks
Old 03-20-2013, 12:19 AM
crizdee's Avatar
crizdee crizdee is offline
Default Re: No virtual instruments for express
Originally Posted by Spidey5150 View Post
Thanks
Express includes boom drum machine, structure free sampler, and xpand 2.
No separate ilok auth is needed, just the one ilok auth for everything.
They should be under instruments in the plugins list! And most instruments require a stereo track.
Chris
Producer, Engineer,
www.ukmastering.com
Old 03-20-2013, 06:24 PM
Spidey5150's Avatar
Should that be under audio suite? It just says "none" there. I can't find any effects either. Maybe I should uninstall and try installing it again.
Old 03-20-2013, 07:18 PM
sunburst79 sunburst79 is offline
The Instruments should show in the regular track inserts. They are not AudioSuite plugs.
Do you have Show inserts check in the Mix Window Shows catagory of the View menu.
Note: I do not have Express so I'm guessing that this information is correct.
Scott
Formerly Hobo Wan Kenobi
Core 2 Specs Page
ASUS P6T6 Revolution | i7 930 | 12GB OCZ DDR3 1600 7-7-7-20 | PTLE 10 | CPTK | 003 | Presonus D8 | 11Rack | Alesis AI3 | Presonus HP60 | Mercury + Studio Classics | Sound Toys | MasseyPack | Axiom61 | MAudio Keystation Pro 88
Old 06-26-2013, 12:00 PM
jrblackwell jrblackwell is offline
Hi, I'm new also and having the same problem. When I create a new stereo track, then go to "Inserts A-E" and then "multi-mono plug-in" and then "Instruments", the only thing that is there is "click".
I tried to download and install the Avid Virtual Instruments Express 10 2 Installer, and it downloaded, but when I double-click on the "Avid Virtual Instruments Express setup.exe" file, I get an error that says, "Error reading setup initialization file".
Are there any instruments included in ProTools Express?
Thanks.
John
Old 07-25-2013, 04:45 PM
Shakle Shakle is offline
I have protools and express and there are no virtual instruments in mine either. Same thing happened during installation. It seemed to have been included but did not install.
Protools Express 10.3.3 and Native Instruments FM8 on Mavericks GraemeC Pro Tools Express on Mac OS X 4 01-11-2014 09:26 AM
PT Express virtual instruments wont install joebejeckel Pro Tools Express on Windows 3 01-08-2014 02:19 PM
No virtual instruments installed with protools express Rattleshock Pro Tools Express on Windows 11 12-15-2013 04:13 PM
Pro Tools Express Plugins + Virtual Instruments mros12 Pro Tools Express on Mac OS X 2 06-25-2013 08:17 PM
virtual instruments Stu Windle 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 11-25-2002 09:00 AM
