Old 06-03-2019, 03:19 AM
groovebrother groovebrother is offline
Default pro tools crashes when lowering clip volume with crtl+shift+whell
Hello
it keeps on crashing after an edit or two
clips are edited at the same time with the ctrl+shift+wheel command as audio tracks are grouped
any clues ?
thank you
pthd 10.3.10 TDM
MacPro 5.1
chassis pe6r4-i + full accel
My soundcloud page
Mac Pro 2x 2.66GHz 6-Core / 96 Go Ram / PE6R4-i - HD Native - Tempo Sata Pro 6Gb - PTHD : 10 / 11 /12 / Ultimate till 2022.5 - 192 i/o Digidesign - MTPAV - OSX : 10.4 / 10.5 / 10.6.8 / 10.8.5 / 10.9.5 / 10.11.6 / 10.13.6 / 10.14.6 - PowerMac G4 MDD / Pro Tools HD 5.3 / 6 / 7.4x / 8
Old 06-03-2019, 10:10 AM
Default Re: pro tools crashes when lowering clip volume with crtl+shift+whell
i have noticed the following :
let's say the group track has 5 tracks but not 5 tracks playing all the time.
When i edit volumes (grouped tracks on) and if there is a "hole" in the edit window like one track is not playing while 4 of them are, then it crashes almost imediately.
But if i edit volumes when having bypassed the groups tracks on tracks that are only playing then i can do a few more edits but less than ten before it crashes.
wierd ...
My soundcloud page
Old 06-03-2019, 01:55 PM
well ... with two other sessions it works perfectly ...
mabe some slightly corrupted audio or what ever got me in that trouble ...
My soundcloud page
Old 06-03-2019, 01:57 PM
Default [SOLVED] pro tools crashes when lowering clip volume with crtl+shift+whell
solved for me
My soundcloud page
Pro Tools refuses to shift an audio clip by the number of samples I specify hitsville Pro Tools 2018 4 06-15-2018 08:25 AM
Clip gain shortcut (shift + control + up/down) lagging, Pro Tools 11 tek720 macOS 0 05-30-2018 02:20 PM
Pitch Shift Crashes My Pro Tools HD Rig relias Pro Tools TDM Systems (Mac) 2 05-29-2009 09:01 AM
crtl+shift+k works but going to export does not don c 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 02-04-2006 12:00 AM
raising or lowering overall volume on track... SixChurchStreet 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 11 01-16-2002 04:27 AM
