  #41
Old 06-14-2019, 08:05 AM
Default Re: Avid: new HW?? HDX 8 years old!!!
Originally Posted by arche3 View Post
Do you think it's better to use 48 instead of 44.1 if going to 44.1 16 bit wav? Do the sample rate conversation after the fact? Or stay at 44.1 instead of 48?
Unless you have a "perfect" converter, then yes, working at 48k is better. Don't worry about SRC too much.
  #42
Old 06-14-2019, 05:50 PM
innesireinar innesireinar is online now
Agree, you should stay at 44.1 if you are working with sample libraries that were sampled at 44.1 (kontakt, VSL etc.) for avoiding too many SRC.
Avid HDX - PTHD 11.3.2 on OSX 10.10.5 - PT Ultimate 2019.6 on OSX 10.13.6 (II partition) - Cubase Pro 10 - Avid HD I/O 16x16 analog
Mac Pro 5.1 quadcore 2.8 16GB Ram
  #43
Old 06-14-2019, 06:00 PM
Originally Posted by TOM@METRO View Post
44.1 and 48k have paid the bills here for years. In all these years I only recall twice that someone asked for a higher sample rate. And one of them had me convert a 44.1 session to 96 and he said he could hear a huge improvement. What a fun business.
This post is in no way meant as a sample rate suggestion. We should all choose what makes us happy.
In the age of musicplayer forum I remember a post where Roger Nichols said that during a blind test none of them were able to pick which one was the 48khz and the 96khz while he was able to recognize the 24bit compared to 16
  #44
Old 06-18-2019, 12:17 PM
off the wall's Avatar
Sent from my SM-G975U using Tapatalk
Definitely better to work at 48 vs 44.1. All your recording, mixing, EQ, etc is done on the higher sample rate audio. Then do ONE last conversion down to 44.1 at the end. Or better yet, let your mastering engineer convert down to 44.1 when HE is done manipulating the audio.
offthewallproductions
Mac Pro 5,1 3.46 Ghz 12 core, AMD 7970 GPU, SSD boot drive on 6Gb/sec PCIe card, 36GB RAM, MacOS 10.14.5.
Pro Tools Ultimate 2019.6. HDX, UA Octo PCIe cards, HD I/O, C|24 control surface.
Mostly Avid, Waves, Sonnex and UAD Plug-ins
  #45
Old 06-18-2019, 12:21 PM
AlexLakis AlexLakis is offline
Seems like it mostly has to do with your hardware.
SlateDigital, for example, suggests 96k because it "sounds better on their converters."
  #46
Old 06-18-2019, 09:47 PM
arche3's Avatar
arche3 arche3 is offline
At 48k... I'm curious how it would incorporate all my sample libraries? Kontact, maschine expansions, Vienna orchestra, etc... I'm not even sure what sample and bit depth they all are. I've always used 44.1/24bit.
  #47
Old 06-19-2019, 09:58 AM
Most VI sample libraries that I know of are 48k which means there is little to no advantage of running 96k
  #48
Old 07-10-2019, 07:11 AM
Armando Armando is offline
Does anyone know if the current HDX PCIe cards will work in PCIe 4.0 mobos? Or will new updated cards be required?
Armando
  #49
Old 07-10-2019, 07:39 AM
Usually new spec is backwards compatible with old one, assuming the connectors are not changed -- but both will need to be new spec if you wish any extra speed.
Avid has not shared any plans of releasing new cards, which still may not mean they are not around the corder. This kind of info is usually available on release date, not before.
  #50
Old 07-10-2019, 08:06 AM
lucienpalmer lucienpalmer is offline
PCIe is usually backwards and forwards compatible. So you can use a 2.0 card in a 3.0 or 4.0 slot. Also, a new 3.0 graphics card can work in a 2.0 slot (but at a slower speed), etc.
Most Mac users have an HDX card in a 5,1 MacPro with 2.0 slots, while most PC users have had them in 3.0 slots for a long time.
It’ll work fine in the new MacPro.
Pro Tools Ultimate, HDX3 & MTRX + HD MADI
MacPro 3.45 12-core, OSX 10.12
S6 M10 16-5, Dolby Atmos RMU
AJA Kona LHi, Sync HD
www.ToolshedAudioPost.com
WHY did I not do this 10 years ago?! midnightrambler Pro Tools TDM Systems (Mac) 6 08-19-2010 07:23 AM
What now , after all these years ...??? gweber 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 23 05-31-2007 10:56 AM
OT - How was your New Years gig? bigd General Discussion 7 01-05-2005 01:57 AM
OT - 60 Years After D-Day The Weed 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 06-07-2004 01:49 PM
24/96 Two Years away? Mark Jiaras Pro Tools TDM Systems (Mac) 21 12-05-2000 04:14 PM
