Closed Thread
Old 01-28-2011, 05:56 PM
Avid Pro Mixing Support's Avatar
Avid Pro Mixing Support Avid Pro Mixing Support is offline
Exclamation Tech Alert!: 2.8.5/2.9 Firmware Download Issue (Faders 9-16)
Here's a quick heads-up for everybody. We've recently discovered an issue whereby the fader firmware download consistently fails.
If a you are running 2.8.5 or 2.9 do not attempt to manually download firmware to the fader boards. If you do force the firmware download faders 9-16 for any given module will be rendered useless.
The only workaround is to downgrade the software to version 2.8.1 (or lower) and then Upgrade back to 2.8.5 or 2.9. If this is not an option for some reason then contact VENUE Support and we will walk you through a manual reinstall of the firmware files.
We apologize for any inconvenience.
Thanks,
Rich
Old 03-16-2011, 10:01 AM
Jason Stygar Jason Stygar is offline
Default Re: Tech Alert!: 2.8.5/2.9 Firmware Download Issue (Faders 9-16)
If the 2.9.1 update corrects this, is the procedure still necessary?
Can I apply 2.9 without doing the fader firmware, then do 2.9.1 with the fader firmware?
We just received our kits, so I want to make sure to do the procedure correctly.
Jason
Old 03-16-2011, 12:14 PM
aarono aarono is offline
Hey Jason,
You are correct. If you install 2.9 and then 2.9.1, should a forced fader firmware download be necessary, you will *not* run the risk of losing any fader functionality. During the regular software install process 2.9.1 will install all of the correct files to your system, including the files that were not included with 2.9.
Hope this helps!
Aaron
Old 03-16-2011, 12:33 PM
will i have the option to decline the fader firmware option with 2.9?
how will i know if it's going to install the fader update or not?
Old 03-16-2011, 04:27 PM
Hey Jason,
There is no need (or way) to decline installing anything during the 2.9 install process. The issue with unresponsive faders only happens after you've installed 2.9 and then *manually* forced a fader firmware download to your control surface. A 2.9 install alone won't impact any control surface functionality.
Aaron
Old 03-29-2011, 12:54 PM
David Colella David Colella is offline
Will I have a problem if I do the 2.8.6 software update? I am currently running version 2.8.5
Old 03-29-2011, 11:05 PM
No, you shouldn't experience the fader firmware issue with 2.8.6.
Here's the link for those who haven't spotted it yet... http://avid.custkb.com/avid/app/self...p?DocId=394991
Thanks,
Rich
Old 03-30-2011, 05:18 AM
tomibraniste tomibraniste is offline
always is good to make updates
Web hosting
Closed Thread
Tech support alert: 6031 errors with 10.3.2 & ML dtmprod macOS 3 01-03-2013 09:15 PM
002 Surface issue - Faders snap to 0 when Record Enabled, Firmware? Table Syrup Records 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 05-28-2009 12:25 PM
Tech Alert - Installation of Internet Explorer 8 may cause Pro Tools to not launch. DigiTechSupt Pro Tools M-Powered (Win) 0 04-03-2009 12:45 PM
Tech Alert - Installation of Internet Explorer 8 may cause Pro Tools to not launch. DigiTechSupt 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 04-03-2009 12:43 PM
