Old 11-26-2017, 08:23 AM
oortone oortone is offline
Default Mix: Slight flicker on some buttons
I'm going to start mixing again and bought a second MC Mix (grey). I noticed some SEL and REC buttons will flicker. Connected the other MC Mix, which I haven't used for years and it had a similar flicker on some buttons.
Since they both have it, and I can't remember this being the case years ago, I'm wondering if it's related to firmware rather than hardware. I updated firmware to latest.
Anyone else who've seen this?
Screens are fine.
All seems to be working otherwise.
Or if it's hardware maibe some kind of capacitor goes bad by age making the voltage driving the leds unsteady?
Old 11-27-2017, 06:36 AM
studiosus studiosus is offline
Default Re: Mix: Slight flicker on some buttons
Hi there,
Same here. Since Eucon 3.7 some buttons flicker from time to time. But they still work..
Old 11-28-2017, 10:55 AM
EddieJones's Avatar
Do you have the General Pref: Rec/Auto switch press checked or not ? I suspect you have it unchecked right ? If so its the new automation feedback causing it (its a bug)
Old 12-01-2017, 03:46 PM
I'm not sure but I'll check that, thanks.
Old 12-04-2017, 05:10 AM
Hi there,
I have it checked. So the rec button switches automation modes. With shift, it's arming tracks. It tends to flicker more often if I'm in preview and some channels are in trim mode.
By the way it would be very handy if that bug with the red light on that button while in trim and read would vanish soon. I went several times through a song without writing automation because a of that (my bad I know, and yes the new auto indicators are great!)
Old 12-04-2017, 10:05 AM
EddieJones's Avatar
That bug is 2nd in the queue for the engineer so should make the next release.
Old 12-04-2017, 01:18 PM
Great to hear. I thought it had to do with me using the older MC Mix version.
Old 12-28-2017, 04:42 AM
peter.melichar peter.melichar is offline
Yes, confirm I have the same issue on my artist transport. I have it only on the second softkey which is mapped to "Shuttle". When I engage the button and then flick the shuttle left/right quickly and let it bounce back, I get that light flicker, glad it's not a HW issue as the unit is new !
Flicker shultzee13 Pro Tools M-Powered (Win) 0 02-25-2009 06:26 AM
PT8 Waveform Flicker suicune Pro Tools TDM Systems (Mac) 13 02-16-2009 10:03 AM
002 LCD flicker!? Greg Coladarci 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 11-07-2005 06:45 AM
flicker on edit window Cliff Hughes Pro Tools TDM Systems (Mac) 0 01-28-2003 11:45 PM
Waves meters flicker Chris Coleman 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 04-05-2000 10:28 PM
