Levels
Hi all.
My question after all these years is still the same. I don't know how to set volume/input levels in my recordings. What do you do? For example, does it matter if the input signal is strong compared to other levels, even though they read the same way graphically? In other words, when I mix at the end, does it matter if one level is mixed super low to blend in with other tracks? Or are there guidelines for optimal sound? Thanks in advance! Pete |
Re: Levels
That is not a simple question to answer. If I were you I would get a book or look on YouTube for some videos on proper gain staging. There are many variables to consider in the final mix. If your going to add lots of effects to a track like compression etc... You can leave more headroom on the input otherwise if you push the input at recording time you won't have any room left for effects and mastering. So it really depends on the project. Also if things are recorded a little low you can add a little on the back end but if you push too hard during tracking your screwed. I don't consider my self an expert and there are many people here who can give you great advice, but I would start with learning proper gain staging and signal flow. Also things in the digital world vs analog are a bit different when it comes to levels.
I hope this helps. Sean |
Tracking Levels and Playback Levels | paul_g | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 9 | 11-26-2010 05:37 PM |
Creating the best mix levels / playback levels | universe777 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 09-25-2006 10:49 PM |
Broadcast levels vs. Podcast levels... | McBoob | Post - Surround - Video | 0 | 05-05-2006 08:03 AM |
Linking track levels w/ pre-fader bus levels? | Bezo | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 11-07-2003 10:36 PM |
Mix levels vs. monitor levels | badshirt | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 6 | 10-05-2001 12:17 AM |
