deleting blank space at end of tracks
I am new to Protools. I created a 15 minute audio progam with two tracks: voice and music. I imported an audio file (music for track two. The file was 30 minutes and I cut it down to 15 for this track. The cut out portion left a long empty space at the end of the progrom which I cannot delete. The result is the final rendering leaves a long blank space running after the program is complete. Any suggestions on how to cut this empty section out?
Thanks so much for the help. Ron |
Re: deleting blank space at end of tracks
There's probably an automation breakpoint or two at the place where the music originally ended. Sometimes they're automatically placed there upon import. Switch to the volume graph on all tracks (hold down the Alt key while switching one track, if WinXP). Select the region of time on all tracks from the end of your last audio to the end (Ctl+Shift+Enter on WinXP), and choose Edit->Clear Special->All Automation. That should do it.
BTW, you can bounce down any portion of a session by selecting the range of time before bouncing.
David J. Finnamore PT 2023.12 Ultimate | Clarett+ 8Pre | macOS 13.6.3 on a MacBook Pro M1 Max PT 2023.12 | Saffire Pro 40 | Win10 latest, HP Z440 64GB |
David,
Thanks so much for the help. Chosing the section that I want to bounce turned out the best. Ron |
Select unused part(s), hit backspace. Select unused files & remove them.
Select remaining audio & do: “Compact Selected”.
MBP early 2011. Apple MacPro 5.1 12Core ”Westmere”. DeckLink HD Extreme 3D+. OS X10.10.5 PTN|10-11. PTN|HD|10-11-12. 16 x 16 HD I/O - 16 x 16 192 I/O Lots of gear. http://www.mmvstudios.com |
Inserting blank space and/or another music section into your session? | EVOLVIST | Pro Tools 10 | 3 | 12-11-2013 01:06 PM |
Deleting blank space at end of a track. Help! | Dylan Mitchell | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 05-14-2007 11:17 AM |
removing blank space, time from sessions | lunads | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 07-30-2004 09:37 PM |
HELP! - can't delete blank space at end of song b/f bounce to disk | Joseph Anderson | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 9 | 03-26-2003 08:57 PM |
How do you insert blank space at start of song?? | pedrohead | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 05-20-2002 11:20 AM |
