Old 06-22-2006, 06:00 AM
s.d. finley s.d. finley is offline
Default Card order in PCI slots
I have a HD2 Accel system in a single 1.8ghz G5. There is a capacitor on the motherboard on the G5 which makes it difficult, nearly impossible, to insert the HD core card into the 1st PCI slot near the AGP card. So, instead I have the core card in the next slot, and the Accel card in the last slot. In the the first slot I have a UAD card.
I notice that the Digital 192 must be plugged into the Accel card to be seen by PT. I am wondering if I am losing any power by using this configuration.
any advice?
thanks
sdf
sdf
www.sugarhillstudios713.com
Old 06-22-2006, 10:01 AM
DigiTechSupt's Avatar
Default Re: Card order in PCI slots
So, is your core card being seen by Pro Tools? Are you saying the interface won't be seen if it's connected to the core card?
That capacitor shouldn't block usage of the PCI slot. Is it possible to nudge it over to make enough space to put the Core card in the first PCI slot?
Avid Audio Tech Support
Support FAQ
Old 06-22-2006, 11:37 AM
[quote ]So, is your core card being seen by Pro Tools?
[/QUOTE] Yes
[QUOTE]
Are you saying the interface won't be seen if it's connected to the core card? [QUOTE]
Yes, this is correct
I am kinda nervous about pushing the cap around, its stiff and doesnt feel like it wants to give.
However, I might feel ambitious later and give it a go...
thanks
sdf
sdf
Old 06-22-2006, 03:32 PM
studiojimi's Avatar
studiojimi studiojimi is offline
less of a chance that it will break if the wires are warm.
do it right after you turn off the box
CAZADOR RECORDING
PT10.3.10/HD6/192w16in/MTN.LION OS 10.8.5 / Westmere MacPro 8 Core W/20gRAM MAGMA-PE6R4/TDM&RTAS/WAVES Platinum/UA/Eventide Plugs/I usually record at 88.2
With GOD as my partner. . . I need to make my plans LARGER.
Problem using 3 card system in a mixture of PCI-x and PCI slots kirkgale Pro Tools TDM Systems (Win) 57 01-28-2011 07:35 AM
Which graphics card lets me use all PCIx slots? markthompson Pro Tools TDM Systems (Mac) 6 08-26-2009 07:38 PM
96 i/o card slots PSI General Discussion 2 12-16-2002 06:29 AM
Best slots for 001 PCI card and RAM chips? imp 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 7 11-06-2001 09:46 AM
G4/800 Dual+ATTO+DIGI-001 PCI slots order? Russo 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 10-24-2001 01:04 AM
