Old 01-31-2017, 09:15 PM
Seafoam_Green's Avatar
Seafoam_Green Seafoam_Green is offline
Default Instrument Track - No Input Monitoring Button - Why ?
I am curious as to why Instrument tracks do not specifically feature an input monitoring button the same as Audio Tracks do ?
I am answering my own question here (below) ..,
And that is because the Tracks REC Ready button will enable audio from the V.I to be heard.
..., but still curious as to reasons why (ie; technically speaking) any V.I inserted on an instrument track MUST be Record ready enabled before it can be heard ?
.., and why can't we have them heard without being being record enabled
The reason I thought of this question is because ...,
When Bluecat Patchbay is run as a Standalone App - I can still play my V.I when inserted in a slot ...., and Patchbay has no REC Ready button - so why can't Pro Tools allow this also
Pro Tools 2018.1 Native * Slate Raven MTi-1 Version 3.3.0 * AVID MBox3 Pro * OSX Sierra 10.12.6 * MAC PRO (late 2013) * 3.5 GHz 6-Core Intel Xeon E5 * 64 GB Ram 1866 MHz DDR * AMD FirePro D300 2048Mb * Lacie LBD 1TB Thunderbolt 2 PCiE * Blackmagic Multidock Thunderbolt2 (Broken !!! - shyte support from Blackmagic Singapore > A-Holes) * Samsung SSD's 850 Pro * WD Black HDD's
Old 02-01-2017, 12:56 AM
Stig Eliassen's Avatar
Default Re: Instrument Track - No Input Monitoring Button - Why ?
Setup (menu) > Preferences > MIDI tab > Default thru instrument > First selected MIDI track. No need to have the track record-enabled to hear it.
Old 02-01-2017, 01:17 AM
midnightrambler midnightrambler is online now
Doesn't that just enable MIDI on the first track on the list, rather than the track you've actually selected?
Old 02-01-2017, 02:52 AM
First VI track in the session with none selected, otherwise the selected track.
Old 02-01-2017, 03:11 AM
Ah right, thanks!!
Old 02-01-2017, 08:45 PM
thx Stig
Old 02-02-2017, 04:16 AM
Is it possible to have a few instruments hooked up using this method and still be playable .., say for example crew wanted to jam away without recording until they felt ready ?
I know that record enable should allow this , but just wondering if there were any other options available to achieve this without record arming the instrument track ?
Also is record arming adding any extra latency of CPU usage than without ?
Old 02-02-2017, 02:17 PM
You can't have multiple VI tracks selected and audible without record-enabling them. I'm curious; why are you wanting to avoid record-enabling tracks?
I haven't noticed any difference in latency or CPU usage, but I don't know the technicalities happening "behind the scenes".
Old 02-02-2017, 02:38 PM
I can't speak for the OP but I sometimes like to jam along with other musicians using VIs, but really don't want to record all my bum notes....
Old 02-02-2017, 03:32 PM
Carl Kolchak Carl Kolchak is offline
Exactly - if you are recording on any other track, it means all armed tracks get recorded.
Sometimes you just have to go back to the old way of doing things, and use a MIDI track in combination with an Aux track.
Track Input Monitoring in 12.2 john1192 Pro Tools 12 1 09-08-2015 11:59 AM
Track Input monitoring!? realizment Pro Tools Software (Mac) 9 11-04-2013 01:51 AM
track input monitoring vin7 Pro Tools 10 6 08-28-2012 07:08 PM
clicking track input button hangs protools wade1der Pro Tools TDM Systems (Mac) 0 06-16-2006 01:22 PM
Audio input monitoring button on C24 tamtamstudio ICON & C|24 0 11-23-2004 06:12 AM
