Old 03-31-2013, 02:14 PM
hydraonstimpac hydraonstimpac is offline
Default HD OMNI input settings i/o
I have a brand new HD Native with Omni setup. This is what i am experiencing.
If a mic is in mic 1, in pro tools a signal is received on both analog 1 AND 2?? and when a mic is in mic 2 there is no signal in either 1 or 2.
Omni Settings: both 1 and 2 are set to Mic not line or instrument. both preamps are set to +10, both have 48v sent because the mics require it.
Pro Tools Settings: Setup >> Hardware Setup >> Main >> under 1-2 it is set to analog 1-2, 3-4 is set to analog 3-4
What am i doing wrong?? please help!
Thanks!
-Nick
Old 03-31-2013, 04:03 PM
KMcK KMcK is offline
Default Re: HD OMNI input settings i/o
First try a factory reset on the Omni, but if that doesn't work it'll have to be sent in for repair.
Depending on your reseller you might be able to exchange it for a properly working unit since its brand new. It's a hardware issue, you're not doing anything wrong.
http://www.imdb.com/name/nm2384808/
Old 03-31-2013, 06:46 PM
That worked! Thank you! i am glad it was nothing more serious.
HD Native, Omni - lost settings, can't reconfigure jeffinaustin Pro Tools HDX & HD Native Systems (Mac) 2 09-10-2013 02:00 PM
HD Omni Line input 2 faulty? bloodstar57 Pro Tools HDX & HD Native Systems (Win) 0 08-24-2013 08:39 AM
Omni mic input problems basicbass Pro Tools HDX & HD Native Systems (Win) 1 03-31-2013 04:02 PM
HD Omni low input levels idris Pro Tools 10 6 02-25-2013 03:02 AM
Omni Mic Pre input problem polkbrosmusic Pro Tools HDX & HD Native Systems (Mac) 2 07-02-2012 06:07 PM
