Go Back   Avid Pro Audio Community > Legacy Products > Pro Tools 2020
Old 07-03-2020, 06:06 AM
zelenov zelenov is offline
Default Pro Tools does not use the entire CPU
I was surprised to notice that ProTools uses only 4 cores, is this normal and what should I do?
Mohave,PT2020.5
Old 07-03-2020, 07:02 AM
sw rec sw rec is offline
Default Re: ProTools does not use the entire CPU
If it’s working, I’d say leave well enough alone. (It’s common to reserve at least two cores for the OS.)
Old 07-03-2020, 08:28 AM
Michael Carnes's Avatar
Michael Carnes Michael Carnes is offline
Development Partner
I wrote this up a while ago:
https://www.pro-tools-expert.com/hom...d-be-pay-to-it
The short take is that you really shouldn't bother with the PT usage meter. Use the meter that's supplied with the operating system.
Old 07-03-2020, 11:08 AM
henningaround henningaround is offline
Default Re: Pro Tools does not use the entire CPU
But isn't it true that all inserts of one track must live on the same core?
Old 07-03-2020, 11:21 AM
Development Partner
Yes that's generally true. But in my experience, PT does a good job of spreading a load across all cores. That's been true on my 4-core, my 8-core and my 16-core. The usage meter is just awful, but it has been for years. I'd love to see it reflect the truth.
Old 07-03-2020, 11:29 AM
So in general it's awfull but isn't this case here it tends to show what's going on because we have just two tracks and one of them with all the inserts :)
Old 07-03-2020, 11:32 AM
Development Partner
That could be true, but I'd bring up the real CPU load monitor. It's called Activity Monitor on the Mac. If you're using really piggy plugins, then perhaps you can use auxes to set up an alternate path. Bit of a pain with inline, but you can get there.
Old 07-03-2020, 11:35 AM
Thanks for that article Michael, I had never seen it before. The meters *are* super annoying and come up here frequently.
Folks may also need to be a little careful assuming perfectly symmetrical workload distribution across what any meter shows is necessarily the best thing. It may not be the case when CPU core cache effects get involved, or with hyperthreading, or where there are very few plugins involved.
Old 07-03-2020, 11:40 AM
Development Partner
Doesn't matter what you do--you'll always get that bulge in the middle. Several years ago I had a conversation with the chief PT designer at the time. He described what was going on in that meter. It was intended to show some 'other stuff' as well. Perhaps Avid thought it would be primarily of interest for internal analysis. But lots of people use it and are continually fooled by it.
Old 07-03-2020, 12:39 PM
Bob Olhsson's Avatar
Bob Olhsson Bob Olhsson is offline
It's also worth mentioning that I've been told that plug-in design plays a bigger role in spread than the DAW host design.
Bob's room 615 562-4346
Interview
Artists are the gatekeepers of truth! - Paul Robeson
Pro Tools HD 12.8 rearranged an entire project Interactivesound Pro Tools 12 4 04-14-2018 04:52 AM
Turning down an entire mix at once? -GOT IT- Jakay Pro Tools 11 32 08-28-2014 11:45 PM
Possible for Pro Tools 11 to crash entire computer? JChance macOS 6 06-05-2014 06:09 PM
Pro Tools HD 10 Crashing and Freezing Entire Mac blvdrecording Pro Tools HDX & HD Native Systems (Mac) 1 06-19-2013 12:52 PM
Pro tools locks entire computer with loud buzzing!!!! Cirait 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 21 07-10-2010 12:41 PM
