Old 05-04-2020, 02:05 AM
DigitalZombie DigitalZombie is offline
Default Anyone here use Strike 2?
I'm trying to do a simple drag and drop audio export and it's not working. From a video tutorial series I watched from Groove3 it seems like you should be able to just record audio in the Record Export area of the plugin, and literally drag that wav file onto an existing audio track, or it'll create a new audio track if you drag it to an empty space in the editing window. Thing is it's coming in really slow. My tempo is set to 97, the "suggested tempo" of the pattern I'm using is 130, listening to it while the other track play is fine, but when I pull that audio into the session now it's playing at maybe 50 bpm and cuts off at a seemingly random point.
What am I doing wrong here? I'm just trying to put together a scratch drum track to send my drummer and this shouldn't be so difficult.
Old 05-04-2020, 02:39 PM
PatriotsBiker PatriotsBiker is offline
Default Re: Anyone here use Strike 2?
I always recorded straight out to audio tracks in real-time when I used that. If I changed anything at all, I re-tracked the whole thing. Phase issues galore if I didn't.
Old 05-04-2020, 03:20 PM
Do you send all the individual parts to separate tracks, or do you bounce everything to one stereo track? I've only seen examples of how to do the former. I'm a Pro Tools novice, so any advice would be appreciated.
AIR Instruments - How to move the 20gb Strike library (only strike) to HDD DBK AAX Plug-ins 18 07-12-2016 05:00 PM
Problem with Strike 1.5-Pro tools 10 wants to move Strike.dpm to unused folder. We live forever Virtual Instruments 55 09-17-2012 06:02 PM
Strike - Songs recorded with Strike - Post Yours JCWarrior Virtual Instruments 12 05-16-2011 12:36 PM
Installed Strike, activated license with iLok> no Strike. seeeker Virtual Instruments 3 10-17-2010 04:21 PM
DAE error #7400 PC (STRIKE only)????? STRIKE WONT LOAD!! TREBLEBLEED 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 01-21-2008 08:19 PM
