Recording Noise
I have an MBox 2 and an Intel Mac mini. I couple of days ago I my protools began to make a really high pitched noise, it almost sounds like computer noise (i.e. the noise a PC makes when your not playing anything and you just turn the volume way up). Sometimes is happens when I open ProTools, but most of the time it happens when I record enable a track. I thought that the noise may just be a fluke but it also gets onto whatever you record. Now here's the kicker, when I go to change the buffer size the noise stops, but as soon as I hit ok the noise starts right back up again so I'm thinking its a software issue. I've search a thread before with this same problem and I'll tell you what I tried to do to troubleshoot.
1. I use the exact USB cable the MBox 2 came with 2. I turned off the screen saver AND sleep function 3. I have the most recent version of protools (meaning I downloaded the new joints off digidesign) You could chalk it up to being a problem with the new intels, but I had the exact same problem with a mac mini that I had before but somehow or another I got rid of it, I just can't remember what I did. SOMEBODY HELP, this is really cramping my style Art |
Re: Recording Noise
Hi there.
Strange but I´m happy to read you´re post. You´re not alone suffering from that B2 note. However, I use Logic and MBox2 instead of Protools and MBox2. I personally don´t think it has anything to do with settings and software. Tried the troubleshooting as well but without success. I can´t hear the noise through headphones plugged into MBox2 which means it probably has something to do with the power (electricity) and those cables/connections. Still trying to figure it out. Will let you know if I success. |
Re: Recording Noise
I think I got it out. Everything going in and coming out of the the M Box cable wise needs to be balance. All inputs and outputs. Lemme know if it worked for you guys because it worked for me.
Audio Recording Noise Test on a new laptop.How do I reduce fan/system noise? | PeterGreen | Pro Tools 10 | 24 | 01-23-2013 06:38 AM |
Sometimes noise while recording | kolo | Pro Tools TDM Systems (Mac) | 3 | 07-20-2006 12:23 PM |
Recording Noise | n3xus | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 03-13-2005 08:49 PM |
Noise Recording | Sam Yin | Pro Tools TDM Systems (Mac) | 5 | 12-26-2003 12:02 AM |
Noise after recording! | Ivann | Pro Tools TDM Systems (Mac) | 2 | 08-19-2003 09:28 AM |
