MIDI window separate from audio
Here's an idea that has been chasing me for a while: I find that the layout of the edit window works very well for audio files, since all editing happens in a graphic mode, however I so often wish that the MIDI tracks were on an optionally separate window, appearing as a list. Naturally, any and all tracks may be graphically or notationally or eventually (MIDI events) edited. The only advantage of working with two separate programs is exactly that it keeps audio and MIDI distinctively and respectively integrated.
------------------ Marco Marinangeli Magelic Productions, Inc. Compression Records http://www.compressionrecords.com
Marco Marinangeli Magelic Productions, Inc. Compression Records http://www.compressionrecords.com |
Re: MIDI window separate from audio
Amen. Trying to edit midi in a track is horrible - you just end up making all the tracks as big as possible. I'd kill to be able to double click a track and get a window that just has the one track full screen.
Mike |
http://www.stevegalante.com |
Amen is right. I sure hope someone is listening...
Yep another vote for a separate midi window. I am sure that as PT midi gets more in line with the Logic / DP functionality it will become a must.
Simon |
I'm with that. A single click to get to a full screen note editor sounds good. And how about a single click which changes ALL tracks to the smallest (or biggest) size at the same time. And being able to change all Midi tracks to the same editing function (notes/pitchbend/regions etc...) at the same time would be useful for me.
Also (maybe this is possible already and I havent figured it out yet), is it possible to edit note lengths by selecting them and using for example +/- for larger increments and </> for small ones. And can the notes on the edit screen light up as they are played from an external keyboard Cheers ---------- Nocturnal |
I thought that 5.1 had some feature that allowed a single key zoom on a track? Wouldn't that do it?
This thread is interesting because one of the first things I noticed when I started using PT was the tight integration of midi and audio. It is so difficult (in Cubase, for instance) to try to align midi notes with audio waveforms because you can't see them on the same screen. They ONLY appear in separate windows (at a useful resolution). Nudging a midi note to align with an audio hit is visually easy when you've got the two tracks next to each other and zoomed. I what situation would you find a separate window useful? Is it simply to "sort" the tracks by function (audio or midi)? ------------------ LW
Larry PT 2021; MacBookPro M1; 16GB; Spectrasonics; Native Instruments, Toontrack, Waves...too many plugins. |
"I what situation would you find a separate window useful?"
The tracks are simply too small to work in. You end up enlarging tracks to work on them - since there's no key command for this, it's a HUGE time waster. Editing the midi isn't so bad, it just takes such a long time to get the track you want at a resolution where you can see it. With multiple windows, it's much quicker in apps like Logic - double click the track you want to edit, bam it's full screen, close the window when you're done. Mike |
In 5.1 you will be able to hit the "E" key in focus mode and it will zoom in and expand the track[s] to the Large view. It's a start!
------------------ [email protected] <BLOCKQUOTE><font size="1" face="Arial,Helvetica,sans-serif">quote:<HR>The Greatest Risk in Life is Doing Nothing<HR></BLOCKQUOTE>
The Greatest Risk in Life is Doing Nothing |
A seperate window where you can edit (several)selected midi tracks is THE N°1 feature I miss.
Groove Quantize might be number 2. and....just check cubase or logic |
002r not showing up in Audio Midi window or in PT | RuffinMedia | macOS | 2 | 02-15-2012 09:57 PM |
M-Audio 02 not showing on Midi Input Enable window... | jns2005 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 08-10-2007 03:22 PM |
How do you scroll the window with the audio on edit window? | fsilano | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 12-01-2001 09:53 AM |
PC audio & midi: better together or separate? | maxx | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 08-21-2001 03:13 AM |
PC audio & midi: better together or separate? | maxx | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 08-21-2001 03:10 AM |
