NI Kontakt 5.41 Protools 10
I see Kontakt no longer installs the RTAS version Just AAX
Has anyone Jumped in to check the water?? I'm running PT 10.3.4 and it's running smooth with Kontakt 5.3.1 Willthis Version of Kontakt AAX run ok on 10.3.4?? Thanks for your time and Help!!! |
Re: NI Kontakt 5.41 Protools 10
I posted about this in the RTAS subforum. It's in the readme or notes that are with the download. Also remember that PT10 uses aax so you don't need RTAS compatibility. There is good news though - installing the update doesn't wipe out the RTAS version of Kontakt. So if you have an install of K5 and you install the update it should be okay. Tried it here. I am running PT10.3.9 here.
Thanks for the heads up
Ill do a better search for answers next time I was more concerned about how well the aax version would run being fairly new I don't like testing software in the middle of a project Thanks again for your time and help!!! |
The update runs just fine; this was mainly an update to work with the new controller keyboards.
Kontakt 5 and ProTools 11 | kgrahamk | Pro Tools 11 | 17 | 03-16-2015 02:29 PM |
ProTools Le 8.0.5 and Kontakt 5 Problem | megasound88 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 02-25-2012 02:18 PM |
Using Kontakt 4 with Protools 8? | gabrieljay | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 10-01-2010 07:08 PM |
Kontakt and Protools | AmericanCheese | Virtual Instruments | 6 | 05-07-2006 05:51 AM |
Kontakt & Protools 5.3.1 (XP) | Uriel | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 06-14-2003 04:43 PM |
