Advice on soft sampler needed
I've been using Reason's NNXT sampler to play scratch drum parts, but to my knowledge it only gives a stereo L-R out into PT. I would like to separate the sounds, i.e. Kick on one track, Snare on one track, etc. If there is not a way in Reason to do this, can anyone suggest a sampler that can, Battery? Samplitude? Tank youse - rj
I got a fever and the only presciption is more cowbell! |
Re: Advice on soft sampler needed
Correct me if I'm wrong, but didn't Rewire at one time allow you to access different outputs coming out of Reason? I know I just used DP3 as playback for a show, and had a couple of samples in NNXT being triggered by DP3 console buttons that were routed to different physical outputs of my 828 via Rewire. So I know you can do this in DP, why not ProTools (anymore???)?
Paul Peterson Sound Director The Old Globe San Diego, CA |
The full version of Reason allows 64 streams of audio via ReWire. Two are used for the initial stereo stream, the rest are available.
Quad 2.5 G5, 4.5G RAM |
I knew you get more than two streams. The trick to it is to use Reason as a Multi-Mono plug, then you will see all of the different outputs from Reason show up in PT.
Soft sampler | idris | Post - Surround - Video | 4 | 08-31-2011 09:33 AM |
need advice on a soft sampler | electrik noize | Pro Tools TDM Systems (Mac) | 3 | 09-28-2006 08:12 AM |
Which soft sampler | idris | Tips & Tricks | 2 | 01-18-2006 11:10 AM |
Soft Sampler/Synth and/or Instrument Advice | Chris Coleman | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 04-08-2003 02:55 PM |
What would be the perfect (Plugin, Soft Synth, Soft Sampler Library)? | rtcstudio | Pro Tools TDM Systems (Mac) | 3 | 11-16-2002 07:57 PM |
