Go Back   Avid Pro Audio Community > Pro Mixing > Avid Pro Mixing General Discussion
Old 02-15-2018, 09:35 AM
Bunty312 Bunty312 is offline
Default Stereo Mix track to DCP
For my student exercise documentary film project, I had to mix in stereo. After the grading was done in a post facility in Mumbai, they made the DCP using Qube software. Due to a subtitle issue we had to re-do the DCP. We used DCP o matic and the same stereo Mix. But the two DCPs sounded different when played back!
So I converted the audio MXF in the two DCPs into WAV using FFMPEG. To my surprise, the DCP from the post facility had made a mono version of the stereo mix and had the same mono track on the L, C, and R tracks. The Ls, Rs and LFE were empty.
So I went back and checked the DCP they had made for our previous project (this was also a stereo Mix), this time only the Ls and Rs were empty. L, C, R and LFE had some content in it!!
I was wondering if anyone has any experience with this.. Do you verify the audio after the DCP is made, in any way other than listening?
Sent from my Redmi Note 3 using Tapatalk
Old 02-15-2018, 11:52 AM
BScout BScout is offline
Default Re: Stereo Mix track to DCP
I'd ask this in the Post Production subsection and not here.
Sounds like the post facility screwed up. Traditionally, we'd do a quality control listen. Things like this are also obvious on a surround lissajous meter.
Old 02-15-2018, 06:05 PM
Oh.. Sorry about that..
Mono source track made into a stereo Commit track [SOLVED] albee1952 Pro Tools 12 9 09-21-2016 05:30 PM
Dragging non interleaved stereo clips to stereo track changes pan [SOLVED] dalonso66 Pro Tools 11 0 06-02-2016 10:03 AM
On a stereo audio track, the left track is completely dead ckwhy2008 Pro Tools M-Powered (Mac) 1 04-09-2011 04:16 AM
Stereo track vs. Mono track vs. Stereo Interleaved track >>>>>>>>>>> peter parker 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 18 06-26-2002 03:21 PM
can you not copy automation data from a mono track to a stereo track? Felix Tips & Tricks 5 04-09-2002 06:32 PM
