Battery 3 and Pro Tools 8
I'm curious if anyone else has had this problem, or knows of a solution. I have Battery 3 routed into Pro Tools Via MIDI channels and Aux tracks. The cells in Battery are assigned to different MIDI channels, and different outputs, all of which is mirrored in Pro Tools. I've checked my routing several times, and it seems to match up.
The strangest thing is happening. On play back, notes are being dropped, and it's random, meaning its not always the same notes that are being dropped. The funny thing is, if I switch the same routing to run reason 4(MIDI assignments & output assignments), it works perfectly, no notes at all are dropped. Native Instruments hasn't been much help yet. Anyone know what to do? |
Re: Battery 3 and Pro Tools 8
It is with everything. Even with my external synths and drum machines. Ill be recording or playing back and it will skip a note. It is random so I just rerecord and keep moving
I'm curious as to how you're using the separate midi channels with Battery. Seems like it might make things more complicated. Battery has multiple outputs, so if it's for mixing, you can still route them to individual aux tracks for separate processing, and just use one instrument track for Battery.
I ran into a similar thing with Battery 2 in Sonar 8.3.1 What remedied it was to lengthen a parameter Cakewalk calls 'MIDI data prepare' or 'MIDI buffer'. These may not be the exact terms as it's been a while since I've had to deal with it. Either way the upshot was the MIDI notes were being triggered to quickly for the system and software to respond. Had to slow things down. Was maddening because as the OP said it's not the same notes all the time, and sometimes the track would play correctly.
Just one more MIDI problem with PT I guess. |
Battery 3 in Pro Tools | rashade07 | Pro Tools M-Powered (Win) | 2 | 12-30-2010 01:54 PM |
Battery 3 In Pro Tools LE 8 | 15th SINE | Virtual Instruments | 5 | 07-16-2009 01:08 PM |
Can I run Battery in Pro Tools? | Antonio Tarantino | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 8 | 04-12-2003 12:11 AM |
battery and pro tools??? | cosmanova | MIDI | 1 | 09-19-2002 03:42 PM |
NI Battery and Pro Tools LE with G4/400? | P_J | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 10-24-2001 01:25 AM |
