Headphone Monitoring
I'm currently using the spdif out, on the 001, into my digital mixer for monitoring purposes only. Is there any way to, at the same time, use the 001's headphone out so I can have a singer monitor the phones out of the mixer, while I monitor through the 001's headphone out? I've tried it, but, you have to be on analog 1-2 outs to hear it on the 001 phones.
Genuinely, Chris
Genuinely, Chris |
Re: Headphone Monitoring
-You are correct. The headphone output only monitors analog output channels 1-2.
-You can always set up a submix by employing Sends on your tracks to an Aux Input and set the output of the Aux to "Outputs 1-2" so you can montior part, or all, of the session while tracking the singer. (Note: if doing this, make sure S/PDIF mirroring is disabled in the Setups>Playback Engine>Other Options window) Brent [ July 12, 2001: Message edited by: DigiTechSupt ] |
Thanks,
Sounds great. I already run with the SPDIF mirroring disabled. I usually just monitor myself performing everything ( 1 set of headphones) so this is a bit new to me. Thanks again Brent. Genuinely, Chris
Genuinely, Chris |
003 Headphone Monitoring | meanie2188 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 11-11-2010 12:03 PM |
Headphone monitoring | MikeSoloway | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 6 | 07-18-2003 11:11 AM |
headphone monitoring set-ups | Jason | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 6 | 03-23-2000 10:51 PM |
Headphone monitoring with effects ... | phobia | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 7 | 02-22-2000 08:32 PM |
Headphone Monitoring | Greg Malcangi | ProControl, Control|24, Command|8 | 0 | 12-09-1999 11:54 AM |
