Mac mini cant start up with iLok inserted
My Mac mini is 2.3G Intel i7, OS is 10.9.1
I have Protools installed so I have to insert one iLok2 to my mini. Every time I press the power it flash one time and shut down. When I unplug the iLok, The mini can start up normally. Are there some conflicts between Mini and ilok?? |
Re: Mac mini cant start up with iLok inserted
Not sure why this is happening. I can only imagine that the mini thinks the iLok is a bootable drive? Sorry I don't know Macs well enough to steer you on that possibility. You could cheat a bit and connect a USB extendo(AKA "dongle buddy) and connect the ilok after you boot(but there must be a solution as you are the first I have seen to report this issue. I assume you have PT11?
I plug the Ilok directly to the mini. Can Ilok be plunged through a splitter too? |
I have a mid 2010 Mini that I use as my Photoshop and web machine and I use that to sync my iLok2 as I don't like to have my daw go online. The Mini is running OSX 10.6.8 and starts up just fine with the iLok2 plugged in directly. I'm not a fan of hot-plugging devices. |
I help set up an HDX system for a friend on an i7 Mini. It drove us nuts with the iLok. The solution was a USB 2 hub as the above poster said. The strange thing was..... We originally tried a USB 3 hub, and it did not work either. On top of that, I have an i7 Mini with an iLok, and it works just fine.
bookerv12 |
It is Fxxking strange!!!! |
Pro Tools 7.4 freezing when Ilok inserted for Strike | BG41 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 14 | 10-15-2008 09:10 AM |
silence inserted at start and end of mp3? | azenis | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 08-21-2008 04:34 PM |
Do I always need to keep my Ilok key inserted? | sebamars | Pro Tools TDM Systems (Mac) | 6 | 05-14-2005 10:24 AM |
Trouble registering inserted iLok | Renie | Pro Tools TDM Systems (Mac) | 3 | 09-13-2003 01:58 AM |
