Go Back   Avid Pro Audio Community > Legacy Products > Aspera DigiDelivery
Old 11-14-2006, 06:33 AM
andrew3939 andrew3939 is offline
Default more setup issues
my apologies for being such a newbie - and i've scouted through the forum trying to syphen information useful to my particular case but being newbie probably missed it
anyway
[ OK ] IP Address 192.168.1.2
[ OK ] Gateway address 192.168.1.1
[ OK ] The DNS Servers 195.26.36.3 195.26.37.3 appear to be working satisfactorily
[ OK ] Port TCP/80 OUT is open
[ OK ] Port TCP/443 OUT is open
[ OK ] Port UDP/123 OUT is open
[ OK ] Port TCP/25 OUT is open
[ OK ] Port TCP/443 IN is open
[ OK ] Port TCP/22 IN is open
[FAILED ] Port TCP/80 IN
[FAILED ] Some Tests Failed
i've closed the router address 192.168.1.1:80
i'm running p2p network - so no other servers
isp is not filtering any port (80)
set up router sua nat rule to allow 80 through to 192.168.1.2
fixed sdsl ip address is 195.26.41.239
the router does not have a firewall as such, so not sure about nonstandard HTTP requests
can anyone help ?
andrew
Old 11-14-2006, 08:38 AM
DigiTechSupt's Avatar
Default Re: more setup issues
Do you possibly have more than one static IP address coming into your facility? If so, the return http message may be getting routed to the 'default' IP address, rather than the one being used for the server. Setting up a NAT rule to make sure both incoming and outgoing messages are routed through your specific IP address should clear up the problem.
If that's not the case, can you give a bit more detail on any routers, switches or other devices between the server and your internet connection?
Also, what do you mean by "i've closed the router address 192.168.1.1:80"?
Avid Audio Tech Support
Support FAQ
Old 11-14-2006, 09:36 AM
thanks for the fast response
no definitely not more than 1 static ip address going into hub - isp via router supplies only 1 address
the router had lan administration on 192.168.1.1 port 80 which i thought might confuse the issue - so that is disabled
andrew
Old 11-14-2006, 10:00 AM
netgear gs116 gigabit 16port
1x router xyzel 791p
1x digidelivery serv LT
2x pcs (winxp sp2)
2x netgear gs105 each connected to
2x pcs (winxp sp2) + 1x mac osX + 1x dcommand + 1x fader module
Old 11-16-2006, 11:37 AM
could anyone help or point me to someone, or somewhere that can ?
andrew
OS X ? with PT ?.... any issues with this setup? pguy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 01-31-2010 07:33 AM
MIDI Setup Issues Alan Z Pro Tools M-Powered (Mac) 4 09-04-2008 04:43 PM
Setup issues Dfazio Virtual Instruments 2 04-28-2007 06:21 PM
setup issues RobMacki Aspera DigiDelivery 11 02-11-2007 06:25 PM
I/O Setup issues Mark Wheaton Pro Tools TDM Systems (Mac) 1 06-07-2001 11:34 AM
