  #2321
Old 01-31-2010, 03:46 AM
TOM@METRO's Avatar
Default Re: Best Core 2 Series Desktops-Results and Specs
We try.
~ tom thomas
Formerly hobotom
Pro Tools Ultimate 2019.5 HDX
HD Omni and 192 I/Os
Windows 10
Intel Hexcore i7
All Samsung Pro SSDs
Ampex MM1200 2" 24 trk tape
www.metrostudios.com
  #2322
Old 04-15-2010, 02:05 PM
AndySolomon AndySolomon is offline
Smile Re: Best Core 2 Series Desktops-Results and Specs
Hi All,
I hope you're all well! I've done a fair bit of reading about compatible chipsets, motherboards etc etc and just want to check my conclusions are sound!
I'm after providing some specs to our I.T department where I work to allow them to price up 15 new machines for our music tech department, so really want to get this right before I commit!
We will be running M Powered 8.0.3, with an M-Audio 2496 PCI soundcard on Win XP Pro 32bit on a dual boot, so XP can be tweaked to our hearts content. The machines will generally be used for heavy sequencing (lots of RTAS instruments) and audio mixing, but generally not much audio recording as this will be done on two separate machines.
  • From what I can gather, the Asus P5B running the P45 chipset seems to be giving good stability, this information is from replies at least a month old, would you guys say this is still a safe bet?
  • CPU wise, it seems the Q9550 is a good choice with regards bang per buck, is this still the case?
  • I read somewhere in this thread that large capacity GPUs can have an adverse effect, is this correct, or have I misinterpreted this? I was under the impression PT prefers you to run a separate GPU
  • 4Gb of RAM would be best with the /3Gb switch sorted? Any particular makes?
  • 2 HDDs, one system, one audio. Preferably SATA, any particular makes or models? I know the Seagate stuff used to be well regarded?
Any answers or time committed to reading etc is genuinely appreciated
Thanks guys, Peace, Love and good happiness stuff!
  #2323
Old 04-15-2010, 03:17 PM
TOM@METRO's Avatar
The P5Q series is a better choice, if you are not going with the much faster i7 CPU.
· CPU wise, it seems the Q9550 is a good choice with regards bang per buck, is this still the case?
Yes, if you are not going with the much faster i7 CPU.
· I read somewhere in this thread that large capacity GPUs can have an adverse effect, is this correct, or have I misinterpreted this? I was under the impression PT prefers you to run a separate GPU
Yes on both.
· 4Gb of RAM would be best with the /3Gb switch sorted? Any particular makes?
Patriot extreme R2 has been fine.
· 2 HDDs, one system, one audio. Preferably SATA, any particular makes or models? I know the Seagate stuff used to be well regarded?
Western Digital Black drives with 32MB cache are the current favorite.
~ tom thomas
Formerly hobotom
Windows 10
Intel Hexcore i7
  #2324
Old 04-15-2010, 03:45 PM
sunburst79 sunburst79 is offline
Hi All,
XP is very stable at this point. I strongly advise building at least one machine and testing it fairly extensively before you commit to building a bunch of them.
P5B is long discontinued but any of the P5K series should work. I recommend a fullsize ATX board with a graphics slot.
If you can find one they are excellent.
Thats true. Smaller is better. Sometime in the future when PT is running on 64 bit Os that will be less of an issue but at the moment it is. PT's video requirements are extremely modest
Just avoid bargain basement desktop memory and buy some solid midrange performance memory. DDR2 1066 with timing of 5-5-5-15 at 2.1 volts is best. Barring that DDR2 800 with timings of 4-4-4-12 at 2.1 volts is your next best choice.
Look for the WD Black with a 32MB cache or the corresponding Seagate. Avoid any drive with "Green" or power saving features
All things considered you may want to look at a Socket 1366 i7 build instead of a Core 2 Quad. They are a lot more powerful. The Core 2 Stuff has the advantage of being very inexpensive at this point though.
Hope that helps
Scott
Formerly Hobo Wan Kenobi
Core 2 Specs Page
ASUS P6T6 Revolution | i7 930 | 12GB OCZ DDR3 1600 7-7-7-20 | PTLE 10 | CPTK | 003 | Presonus D8 | 11Rack | Alesis AI3 | Presonus HP60 | Mercury + Studio Classics | Sound Toys | MasseyPack | Axiom61 | MAudio Keystation Pro 88
  #2325
Old 04-16-2010, 01:10 AM
TOM@METRO and Sunburst79,
Huge thanks for taking the time to reply, much appreciated. So I get the feeling that a better long term investment would be a socket 1366 board with an i7 CPU, especially considering the potential memory advantages of running Windows 7?
Let me explain my situation a little further. I work for a college teaching Music Tech and have recently convinced the management that they need to upgrade our ailing NEC desktops. Our I.T department will not let me order the parts etc, as internal policy dictates they have to do it, and are pretty convinced they can spec a machine from Dell to do the job (they have a bulk buy education account with Dell). I'm trying to convince them that self building will probably be cheaper and allow us to spec the machines exactly as we want them (albeit with a time and man hours premium added!)
Another quick question for you then, how is Windows 7 with PT M-Powered 8? Presently all our machines will be built using XP, but at some point soon Windows 7 will be rolled out across the entire college, so if it's stable it may be worth considering this option now.
Also any particular graphics cards you'd recommend?
Once again, thank you so much for your time (i'd buy you guys a beer, but it's a long trip!)
EDIT: Looks like I best pop over to the i7 thread for a read..........
Last edited by AndySolomon; 04-16-2010 at 01:11 AM. Reason: Because the poster is a prat and forgot to write something!
  #2326
Old 04-16-2010, 01:57 AM
TOM@METRO's Avatar
Yes, the i7 thread is a good read, and an i7 solution should be considered. As mentioned, the graphics card will depend on the OS as a 64bit system with adequate RAM will not have the same limitations as in a 32bit system.
As far as Windows 7/64 is concerned, The PT drivers are in beta and should be available soon. Some of us are having good luck with the beta drivers and others are having a bit of trouble so I am uneasy about recommending this right now.
I prefer ATI cards with 256-512 MB of RAM.
~ tom thomas
Formerly hobotom
Windows 10
Intel Hexcore i7
  #2327
Old 04-27-2010, 07:22 PM
Michael_Knight Michael_Knight is offline
I'm actually looking at a Dell Studio XPS 8100 I7 I was hoping to get some opinions on it, but you might be able to use it as well
Quote Details
Item Number Quantity Item Description
224-7745
1 Studio XPS 8100
317-2913
1 Studio XPS 8100, Intel Core i7-860 processor(8MB Cache, 2.80GHz)
317-2890
1 8GB DDR3 SDRAM at 1333MHz-4x2GB
330-3828
1 Dell Consumer Multimedia Keyboard, US
320-1075
1 Dell ST series ST2410 24"W Full HD Monitor, 24.0 VIS, VGA Cable supplied only
320-8901
1 AMD Radeon 5450 (1GB)
342-0171
1 1TB Serial ATA 2 Hard Drive 7200 RPM
421-2040
1 Genuine Windows 7 Professional, 64bit, English
420-7938
1 Dell Connect 2.1
421-0530
1 Dell Support Center 2.0 64bit
420-8873
1 Dell Dock Consumer
421-1183
1 Download Store Links
420-6576
1 DELL WELCOME,Software Dimension/Inspiron
420-9691
1 DataSafe Local BackUp 2.0 Basic
420-6436
1 PC-Restore, Dim/Insp
421-0323
1 Windows Live Search,Multiple User Interface
330-6097
1 You have chosen a Windows 7 System
330-6470
1 Dell Resource DVD with Application Backup
421-2087
1 eBay Webslice
421-0756
1 SKYPE VOIP Software Application
330-3826
1 Dell Studio USB Optical Mouse
410-1867
1 ADOBE READER 9.0 MULTI- LANGUAGE
313-9989
1 16X DVD+/-RW
421-1412
1 Cyberlink Power DVD 8.3 Playback
313-8757
1 Roxio 10.3, Easy CD & DVD
421-9898
1 THX TruStudio PC
313-6138
1 No Speaker Requested
430-0682
1 Dell 1525 WLAN PCIe card with11n mini-Card & external antenna
410-2152
1 McAfee SecurityCenter with anti-virus, anti-spyware firewall, 15-months
420-8103
1 Microsoft Works 9.0, English
905-9758
1 Dell Hardware Warranty PlusOnsite Service, Extended Year(s)
905-9757
1 Dell Hardware Warranty PlusOnsite Service, Initial Year
906-7802
1 NextBusinessDay Parts and LaborOn-Site Response, 2YR Extended
907-7750
1 NextBusinessDay Parts and LaborOn-Site Response, Initial Year
960-3642
1 Dell Limited Hardware Warranty 7X24 Technical Support, 2 Year Extended
960-8700
1 Dell Limited Hardware Warranty 7X24 Technical Support, Initial Year
900-9987
1 Standard On-Site Installation Declined
* -DISCOUNT/COUPON APPL
Subtotal: $1,514.00
Shipping & Handling: $0.00
Tax: $89.58
Environmental Disposal Fee: $0.00
Total Price w/Discounts: $1,604.85
  #2328
Old 04-27-2010, 08:08 PM
Bob Olhsson's Avatar
Bob Olhsson Bob Olhsson is offline
I highly recommend the Dell Precision Workstations over their consumer line. They are intended for this kind of work and have tech support people who can relate to what we do.
Bob's room 615 562-4346
Georgetown Masters 615 254-3233
Interview
Artists are the gatekeepers of truth! - Paul Robeson
  #2329
Old 04-30-2010, 12:34 PM
TOM@METRO's Avatar
You can probably get away with this computer if you buy and install a new OS and get rid of the proprietary bloatware. You may need a new TI Firewire card and driver.
All-in-all, you will do much better for less money with a custom build following the guidelines in the i7 thread.
~ tom thomas
Formerly hobotom
Windows 10
Intel Hexcore i7
  #2330
Old 04-30-2010, 02:33 PM
DJ Hellfire DJ Hellfire is offline
Figured I'd post the Dverb results for my setup.
Dell Inspiron 530 w/XP SP3
Q6600 2.4Ghz Core 2 Quad
4GB Dell 800Mhz ram
Foxconn DG33M03 Motherboard
ATI Radeon HD 3650 512 MB PCI Express Graphics Card
ST3250310AS OS Drive
ST3500320AS Audio Drive
300W Stock PSU
159 PT8 Dverbs @ 24/48K 1024MB 95% CPU. Stock clock settings.
www.HellfireBeats.com
Akai MPC 2000XL, Akai MPC X, Mackie 1202VLZ Pro, Akai Advance 61, Focal Alpha 80, UAD 2 Apollo Quad, UAD 2 Satellite Quad, UAD 2 Octo PCIe, Neve R6 "Lunch Box", Neve Portico 511, Neve Portico 551, Neumann TLM49
Pro Tools 2018.10
Mac Pro 4,1 (5,1 upgrade), Early-2009, 3.46GHz Nehalem 12-Core, 32GB RAM - OS 10.12.6
13" MacBook Pro, Late-2011, 2.4GHz Dual Core i5, 16GB RAM - OS 10.12.6
27" iMac, Late-2012, 3.4GHz i7, 24GB RAM - OS 10.12.6
i7 Builds - Specs and Results mykhal c Windows 6780 08-16-2019 05:40 PM
Intel Quad Core vs. i-series solidwalnut 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 11-23-2010 05:16 AM
Have a Quad Core (Asus P5K). Use Only One Core Active For Best Results? MIDI Issues. epu 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 11 08-12-2009 02:24 AM
are these specs ok? (low budget 2 core) korkman 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 8 08-22-2008 02:44 AM
8 Core Mac Pro, Leopard and Windows results pasanta 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 01-13-2008 06:51 PM
