  #1341
Old 07-13-2008, 04:44 PM
mano111 mano111 is offline
Default Re: Best Core 2 Series Desktops-Results and Specs
Hey great computer builders of the DUC!!!! Looks like the quads are strikingly intense still. I know mine is.
I accidentally spilled some beer on my desk and a fair amount spilled over onto the front area of my computer case and I lost 2 USB ports and now the start button is getting very sticky and I'm afraid its going soon. I was wondering if this case right here is a good investment as I should probably order it soon so I don't lose much time. Thanks for the input fellas.
http://www.antec.com/us/productDetails.php?ProdID=81820
P.S. As a side not I have 3, 1 GB sticks of Ram now and am running Windows SP3 and Pro-Tools and Reason are running fine.
1. INTEL CORE 2 QUAD Q6600 (BX80562Q6600) 2.4GHZ EM64T QUAD CORE W/4MB X 2 CACHE 1066MHZ LGA775-PIN RETAIL BOXED W/COOLING FAN
2. ASUS P5K DELUXE/WIFI-AP INTEL P35 CHIPSET ATX FORM FACTOR 2xPCI-E(X16)/2xPCI-E(X1)/3xPCI/4xDDR2 W/SATA2 RAID,DUAL LAN(Gb),1394,USB 2.0 & AUDIO (CPU TYPE:INTEL - SOCKET 775)
3. Crucial Ballistix 3GB (3 x 1GB) PC2-8500 1066MHz 240-pin DDR2 Memory
4. SEAGATE 250GB ST3250410AS SATA2 16MB 7200RPM (Bare drive) x2
5. ASUS EAX1600PRO SILENT/TD/256M Radeon X1600PRO 256MB 128-bit GDDR2 PCI Express x16 Video Card(discontinued)
6. Corsair 520W SLI Certified Modular ATX Power Supply - CMPSU-520HX
7. SAMSUNG Black 18X DVD+R 8X DVD+RW 8X DVD+R DL 18X DVD-R 6X DVD-RW 12X DVD-RAM 16X DVD-ROM 48X CD-R 32X CD-RW 48X CD-ROM 2MB Cache SATA DVD Burner With LightScribe Technology - OEM
8. XP Home Edition SP2-OEM------> Now have SP3 installed
The P182 is a great case. I personally preffer the Antec SOLO. Its smaller, and more quiet right out of the box (with no modding hat is )
It also cost less.
If yo are using a passive video card you may want to add a low speed 92mm fan for intake
http://www.antec.com/us/productDetails.php?ProdID=18500
i7 2600K @ 4.4GHZ -- Intel DP67BG B3 -- 8GB DDR3 1600 -- Crucial SSD
PTLE 8.0.4cs2 -- DIGI 003R -- DV toolkit -- Waves 9
  #1342
Old 07-13-2008, 10:27 PM
lowroller lowroller is offline
The moment of truth...
I've done the 3GB switch and the first time 'round I forgot to put the / in front of LARGEADDRESSAWARE. No wonder it wasn't working.
So I did that step again and all seems to be working very well.. I was a little nervous loading a full layered kit in BFD without being in 16 bit mode, heh, but it loaded PF usage in Windows Task Manager tells me I'm at 1.69GB with the ProTools session I'm running (1.5GB for the BFD samples I guess).
Thanks heaps for the heads up with this. This machine is living up to expectations now
  #1343
Old 07-14-2008, 12:43 AM
mykhal c's Avatar
mykhal c mykhal c is offline
glad you got things dialed in
bassist...deep pocketz anyone???!!!
The Basschakra Lucid Soul Trip
i7 Builds - Specs and Results
HDNative | Omni | i7-3930K OC'd 4.0GHZ |
ASUS X79 Sabertooth | 32GB GSkill DDR3 2133 ram | mo' stuff
  #1344
Old 07-21-2008, 04:00 PM
JPS JPS is offline
Default
lowroller, I put together a self-built DAW that is similar to yours... and I am very impressed. Mine also is definately living up to expectations!
Here are the basis specs:
Gibabyte GA-EP35-DS3P ($95)
Q6600 - GO stepping ($189)
Xigmatek S1283 Cooler ($35)
LIANLI|PC-7B PLUS II BLK ($89)
GSkill DDR2 1056 2GB ($59)
PSU CORSAIR|CMPSU-450VX ($79)
VGA ASUS EAH3450/HTP/512M RT ($43)
DVD BURN LITE-ON|LH-20A1L-06 ($34)
Western Digital HD 320G SATA2 WD3200AAKS ($70)
I am very pleased with the motherboard performance. The Gigabyte motherboards do have DPC Latency"spikes" issues, but they were fixed on this board with the F4c Bios. Latency is great at 4-8ms and No spikes! The integrated onboard firewire ports work fine with PTLE and it's nice to know Gigabyte uses the Texas Instruments chipset, which is the chipset in the Digi recommended firewire cards. The mobo also comes with a eSATA PCI card, which may be nice for recording on drives without installing them in the system.
Overclocking? Oh yeah... it looked like a lot of fun and I wanted to join in...and the results are way out there! The board has a heat pipe on the North bridge to help keep things a little cooler. I've never overclocked before but this board makes it easy with an automatic voltage control option. Sweet!
Anyway, the setup is very stable at stock settings and has produced no errors, other than the expected -9129 Out of CPU power.
Results:
D-Verbs at 2.4 ghz= 255
D-Verbs at 3.6 ghz= 360
No, that's not a typo and I was pretty surprized I was able to hit 3.6. Of, course, I don't plan on leaving it there, it's a little too toasty at 61C. Perhaps a more mild 3.2 ghz, which is very stable, reboots fine and still produces a very usable 325 D-Verbs. Oh, all the options...
As Sunburst mentioned, I was quite concerned I might fall under the 315 D-Verbs.
Anyway, this has been a lot of fun putting this together and testing it. And I am sooooooo glad I didn't go with a Dell. This setup is very quiet, powerful and lots of extra power, if needed. The only thing I might have done different is to buy the Patriot DDR2 1150 memory. Based on my testing it would get me about another 12 or so D-Verbs.
My old P4 2.8 ghz Norwood CPU got me 24 D-Verbs in a ASUS P4C800 motherboard. The Q6600 has 10x the processing power. Got to love those quads!
Edit on 7-27-08:
D-Verbs at 2.4 ghz= 235
D-Verbs at 3.42 ghz= 325
Test Results were edited because the original test was not conducted at 24/48. A new test was conducted at the correct setup 24bit/48K and produced the above edited results. Sorry for the mistake.
John-Q6600,GA-EP35-DS3P, Zigmatec S1283: 235 D-Verbs @ 2.4 ghz
Last edited by JPS; 07-21-2008 at 05:36 PM. Reason: to add additional descriptions
  #1345
Old 07-21-2008, 04:45 PM
mykhal c's Avatar
Default
congrats john. excellent scores!!!
  #1346
Old 07-21-2008, 05:19 PM
JPS JPS is offline
Default
Thanks, mykhal
It was you and all the other quad guys that gave me the psychlogical boost to do this. You guys took the chance and did the work to make sure they worked correctly with PTLE, and I got the benefit. And I do appreciate it! Thanks.
  #1347
Old 07-21-2008, 05:51 PM
mykhal c's Avatar
Default
Originally Posted by JPS View Post
Thanks, mykhal
yeah man, like you, i appreciate all the knowledge that is shared in the thread and DUC!!! it was my 1st build and i totally enjoyed the process and result.
how are your temps?? i've got the same case and like it a lot. since i decided to leave my box OC'ed i decided to put 2 additional MASSCOOL 80mm fans in it. one on top as an intake and one on the side vent as an exhaust, right at the graphics card. so now my temps are pretty close @3.10ghz as they were @2.4ghz kinda nice!!
  #1348
Old 07-21-2008, 07:24 PM
JPS JPS is offline
Default
Honestly, I have not looked a lot at the temps yet. At 3.2 ghz when running full load, my CPU is 60-62C and the system shows 38-40C. When it goes back down to idle, then the CPU reduces to about 40C. I have been using the Easy Tune Center to monitor the temps. It does increase the DPC Latency, so I would rather have something else for monitoring temps, but just not sure what at this point. I assume my temps are OK, but nothing great.
I went with the Xigmatek S1238 cooler because it got pretty good reviews on Newegg, was reasonably priced, fairly quiet and was good when overclocking. There is a $10 rebate off the price I paid.
I like Lian Li cases. I built my first computer 4 years ago with Lian Li and I like how light the cases are. The newer cases are much improved and I love the big and quiet 120 mm fans- both of them. Since I have a fanless and rather simple video card, I don't make a lot of extra heat, so I am not planning on adding more fans. So far no problems and rather pleased with the system.
  #1349
Old 07-23-2008, 09:16 AM
sunburst79 sunburst79 is offline
Default
Results:
Thanks, mykhal
Nothing agaist DELLS but these work so much better for the same or less money.
This has been a community effort and I'm still amazed at how well they work, how cost effective they have become and I'm not aware of anybody that we haven't managed to get up and running using a "Q approved" Intel chipset. And I can tell you (along with MykhalC, Shan and a few others) that from the emails I have received that the posts in thread are the tip of the iceberg as far as the actual number of builds go.
With a little bit of digging and posting you can always find help on the DUC, by Skype or POTS (Plain Old fashioned Telephone Service)
FWIW if you had really run into problems I would have driven over to help solve them. Your pretty tech savvy though.
It's a lot of fun to build this stuff, Do the research, find the parts, shop for price and built it. Lot of things I like about OSX and Apple but there will always be a a part of me thats part street rodder/drag racer/rocket scientist/casemodder/system builder that always has me looking forward.
Its pretty cool to look at that box and say 10x more powerful.... and know you built it.
Welcome to the Core!
Scott
Formerly Hobo Wan Kenobi
Core 2 Specs Page
ASUS P6T6 Revolution | i7 930 | 12GB OCZ DDR3 1600 7-7-7-20 | PTLE 10 | CPTK | 003 | Presonus D8 | 11Rack | Alesis AI3 | Presonus HP60 | Mercury + Studio Classics | Sound Toys | MasseyPack | Axiom61 | MAudio Keystation Pro 88
  #1350
Old 07-23-2008, 01:22 PM
mlange's Avatar
mlange mlange is offline
Default
Originally Posted by sunburst79 View Post
.... I'm not aware of anybody that we haven't managed to get up and running using a "Q approved" Intel chipset.
Hey Sunburst79,
Not to be stupid, but I've been pouring over posts for quite some time and am getting ready to jump-in. Which current model production MB's are "Q approved" for the Q6600 or Q9540 CPUs? Each listed Asus board I've checked into is no longer available at Newegg, and I'm Jonesin' for 300+ dverbs :)
Thanks!
________________________
www.PlethoraTone.com
PlethoraTone Studio Video Tour
At PlethoraTone:
Intel Core i7-4960X, Asus P9X79 LE, W7 Pro 64-bit, 16GB DDR3,
Avid HD Native, Pro Tools HD v10, 4/192 I/O, 2/UAD-2 QUAD,
Tascam US-2400, Exponential Audio, PSP, Kush, Slate Digital,
Waves Mercury, PA, Melodyne, Antares, Audioease, SoundToys
i7 Builds - Specs and Results mykhal c Windows 6780 08-16-2019 05:40 PM
Intel Quad Core vs. i-series solidwalnut 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 11-23-2010 05:16 AM
Have a Quad Core (Asus P5K). Use Only One Core Active For Best Results? MIDI Issues. epu 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 11 08-12-2009 02:24 AM
are these specs ok? (low budget 2 core) korkman 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 8 08-22-2008 02:44 AM
8 Core Mac Pro, Leopard and Windows results pasanta 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 01-13-2008 06:51 PM
