Old 10-28-2011, 05:20 PM
audiocontrol audiocontrol is offline
Default HD Native not powerful enough ?
Hi Guys,
I have the following session as my goto-template:
- about 64 channels of audiotracks (most mono)
- 8 aux inputs stereo as subgroups
- 5 auxes stereo as headphone feeds
- 4 auxes stereo as FX
- 1 stereo master fader
- 8 VCA-groups
- 6 stereo instrument channels
That's about it.
There's no media, plugins, content or whatever.
It's just the channels, to have them right at my hand.
- When I open 5 pre-fader bus sends on each track as headphone mixes, the session won't even play back at 64 samples of latency.
OK, maybe too much.
But when I open 1 instance of Kontakt 3 with a grand piano, I'm not able to record a single track at 64 Samples. I need to go to 256 Samples.
What's the problem ?
Again, there's not media or any plugins in the channels.
My system is: Mac Pro, Quad 3,7 GHz, 16 GB RAM.
Setup is: 4 CPUs at 85 %
What can I do ?
What do I do wrong ?
Thanx in advance
audiocontrol
PT 2018.12, Mac Pro, HDX, S3.
Old 10-28-2011, 05:35 PM
lennieh lennieh is offline
Default Re: HD Native not powerful enough ?
There a setting in Kontakt to set the number of Cores you use, you need to turn this off, it clashes with protools which is also managing the CPU load via the playback engine settings. try that
Old 10-28-2011, 08:48 PM
nst7 nst7 is offline
There is something else going on in your system. You should not have problem with a session like that, especially on HD Native with a Mac Pro.
Old 10-29-2011, 03:15 AM
Thank you guys, that's what I thought, too.
But what could it be ?
Any suggestions ?
Do you need some more info of anything ?
Old 10-29-2011, 03:28 AM
wmcintyre wmcintyre is offline
try reducing the 4 cpu setting to 3.
Old 10-29-2011, 04:47 AM
danander11 danander11 is offline
Hold the shift key down whilst you open the session. See how it runs then.
If everything is cool, start activating plugs one at a time until you see a problem.
Here I am,
after time not long...
and thankful for the break,
What I found when I got there,
was that I couldn't stay away!
Hobo Shave!
Old 10-29-2011, 09:55 AM
Hi Danander11,
thank you for the hint.
This just doesn't help me, as there are no Plugs in the session...
audiocontrol
Old 10-29-2011, 11:17 AM
glennaudio glennaudio is offline
I agree. Set CPU usage to one core less than the maximum but at 99%. See if that helps.
MacPro 5,1: 12-core 2.93 GHz 48GB RAM OS X 10.12.2 | Pro Tools HDNative 12.7.1 | HD I/O 8x8x8 | UA 4-710D | Avalon VT737 | Waves Diamond | Komplete 12 Ultimate Collector's | Kontrol S61 | Maschine Studio | Eleven Rack | Pro Tools Control w/ 9.7" iPad Pro | Pro Tools Dock
Old 11-01-2011, 02:52 PM
Hi guys,
so now I did what you guys said.
In fact, changing the engine settings in Kontakt didn't do a thing.
Changing the CPU-thing from 8 / 85% to 7 / 99%, didn't do anything either.
Updating Kontakt from 4 to 5 brought a huge difference.
But still...
When I open a session with 60 tracks.
All got 4 FX-Sends and 5 HP-Sends. Nothing else in the session.
I can't hit play at 64 Samples.
Is this normal ?
Can somebody verify ?
What does DigiTechSupport say to it ?
HDX2 or 2 HD Native Systems, which is more powerful? ggegan Pro Tools HDX & HD Native Systems (Mac) 17 02-26-2014 07:23 AM
Does HD native or native native disable plugins when monitoring inputs? BasketCase Pro Tools HDX & HD Native Systems (Mac) 7 05-20-2013 08:48 AM
Discussion: What are the most POWERFUL native PTLE Systems ever built? epu 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 07-29-2008 07:58 PM
What components lie in the most POWERFUL native PTLE Systems? epu 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 07-28-2008 07:18 AM
SSL4000 native/ Renmaxx native/ DUY everpack native!!! cary chilton 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 03-22-2007 07:58 AM
