No playback after CPU error
Hi there, from time to time I get the good old "running out of CPU" error, which halts playback. However, when I try to restart playback again, I don't get any audio - nothing. All the meters are going up and down on screen, it looks like it's playing back, but there's no audio. It's like the connection between the computer and the m-audio box has been lost.
The only way I have found to fix this is by restarting my computer... which really isn't practical every time I get an error!! Anyone know how to "reset" the audio settings so that it will talk to the m-audio box again and play music? Thanks heaps Jared MacBookPro 2.33Ghz PT 7.3.1 M-powered |
Re: No playback after CPU error
Have you updated to 7.3.1cs7?
http://digidesign.com/index.cfm?navi...&categoryid=36 Sounds like you're experiencing the 'Brain Freeze Bug' Fixed: Intermittent Graphic Freeze When Using Pro Tools (Item #82932) Pro Tools would continue to play while the GUI was frozen, with intermittent plug-in automation and MIDI playback, and then unfreeze. If that's not the ticket I would use the uninstall app and choose 'clean uninstall' and then reinstall 7.3, then the 7.3.1cs7 patch Or even better go to 7.4 which is more stable in my opinion. Post back if still having issues, also post the DAE error number you're getting. Which M-Audio model/peripheral used. Disconnect other peripherals and run just the M-Audio interface and Pro Tools and move all plug-ins out to a temporary folder. Sometimes out of date plug-ins can cause audio drop outs too. Mac HD / library / app support / Digidesign / Plug-ins, move them all out and restart pro tools. Your session will have all its plug-ins inactive, but now you can test just Pro Tools and see if its working or not. Plug-in Compatibility: http://digidesign.com/index.cfm?lang...n=news_details |
which interface? This has happened with my FW410 from time to time. Try resetting the mixer, if that doesnt help a restart is in order. Also download the latest driver from m audio.
Playback error. :( | Samyas | Windows | 1 | 05-11-2012 08:01 AM |
Pro Tools 9 Playback Error Lead to DAE Error 743 Which Lead to A CPU Overload Error | EricMulhern | macOS | 1 | 11-20-2011 05:39 PM |
Error 9073 and Error Increase/Reduce H/W Size during playback Digi001 | Karma180 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 11-05-2011 07:46 PM |
Playback error in 6.9 LE | WindyCityUSA | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 12-03-2010 12:38 PM |
Playback Error | sevenfigureinc | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 10-16-2006 10:54 AM |
