Old 04-30-2015, 10:45 AM
fourthtunz fourthtunz is offline
Default Reasons to upgrade from 10 to !!?
I tried to find threads about reasons to upgrade but no luck SO...
What are the reasons to upgrade from Protools 10 to Protools 11
Im not a power user by any means..
still using an 11 rack and an old 002 rack..on a 2011 mac mini 2.0 quad processor
I remember something about MORE POWER :)
seriously though..
Are there more and better different plug processing options?
what am I missing out on?
Don't care about subscribing to 12 right now ;(
by the way..my pt 10 isn't going to vaporize if I don't upgrade to 12 right? :)
thanks for your time in advance!
Old 04-30-2015, 10:49 AM
Phil Ogden Phil Ogden is offline
Default Re: Reasons to upgrade from 10 to !!?
As I understand, PT11 is 64 Bit and, as such, can address more RAM. One of the main benefits of this is with sample based VI's. If you use them in any significant way, then you may see better performance from v11.
Old 04-30-2015, 10:55 AM
8dB.co.uk 8dB.co.uk is offline
PT11 appears to have about 2.5 times the processing capacity. I saw sessions drop from 70% usage on PT10 to 25% usage on PT11.
Pro Tools Utimate 2018.7, on -
i7 5820k 6 x 4GHz (12 threads), 16GB DDR4, Win 10 Pro, BM Mini Monitor PCIe, GTX 660Ti 2GB;
Dell Laptop, i7 4x3.6GHz (8 threads ), 16GB DDR4, Win 10 Pro, GTX1060MaxQ 6GB;
"Plan B" - i7 6700k, 4 x 3.4GHz, 16GB DDR4, Sierra, AJA Kona LHi, GTX 1050Ti 4GB.
RME FireFace802 + ARC, RME Babyface
Avid D-Command, Artist Control, V-Control, Korg MicroKontrol
7.1.2 Presonus Monitors
And Audio suite processing is much faster.
Old 04-30-2015, 07:51 PM
Better CPU allocation is definitely nice, but offline bounce is the big one right?
http://www.richbreen.com
Mac Studio / Ventura, PT 2023.12.HDX, Avid HD I/Os and Metric Halo ULN8, 3xS1/Dock
Also running a Mac Studio Ultra / Ventura / HDX / MTRX / S6
Old 04-30-2015, 07:55 PM
For me, PT11 has been a great move up. Waaaaay more power for plugins and VI's. Off-line bounce saves me a lot of time. Stability has been somewhat better(not perfect, but the minor issues I have may well be my own fault) As for PT12.......still on the fence. Doing some trials with it, but my daily working setup is 11(I use a separate system drive for experimenting with new versions, and ALWAYS save a drive image BEFORE updating a good-working system drive)
Old 05-01-2015, 06:18 PM
DC-Choppah's Avatar
DC-Choppah DC-Choppah is offline
Don't look back.
PT 11 is like the same as buying a 2.4x more powerful computer in terms of the number of plugins and VIs you can use before topping out.
Huge improvement.
DC-Choppah's Project Studio:
ASUS PRIME Z390-A / Intel i7 rackmount PC
Windows 10 home 64 bit
Pro-Tools 11.3.1
AIR Instrument Expansion Pack v2
WAVES Platinum plugin bundle
Tascam US-16x08 Interface
100% Analog real time monitoring 16x4
Yamaha 16 channel MG16XU Analog Monitor Mixer
Yamaha MX-88 / Novation XiO keyboards
Mackie 4-channel headphone amp
Adam A8X monitors
Blue / Shure, etc. microphones
Estonia 6' 8" Parlor Grand Piano
Yamaha Studio Drum kit
https://www.dc-choppah.com/
Old 05-01-2015, 06:44 PM
mesaone mesaone is offline
Unless you rely on gear that isn't supported in PT11 (Control24, HD core and accel cards) I can't think of any reason not to upgrade.
Better allocation of resources, large-address aware (can access >4 GB RAM), faster audiosuite processing, more metering options, offline bounce, improvements to the workspace, etc.
Pro Tools HD 12.4, Pro Tools "Vanilla" 12.4, Artist Transport, 2x Artist Mix
Studio Blue: RME UCX, Win7 Pro, i7 960, 16GB || Studio Green: RME Babyface, Win10, i7 7700HQ, 16GB
Old 05-01-2015, 11:45 PM
One reason to upgrade is because you might want to use an operating system that is not 2 generations old. Protools 10 is only certified to work up to Mountain Lion (10.8.x). It is not certified (has some uninstall problems) with Mavericks (OSX 10.9.x). It is not certified (can't install, can't uninstall, and has a bug with displaying drop down list of plugins in inserts and sends) with Yosemite (OSX 10.10.x). Avid has explicitly said that they will not fix Protools 10 to work with any OS newer than Mountain Lion…forever. So if you want to run a more recent OS or you buy a Mac that can't run an older OS, you'll need to upgrade to Protools 11 or 12.
Obsidian Dragon
Mac Studio M1Max - 64GB
Old 05-02-2015, 11:48 AM
briaboy briaboy is offline
I'm using PT10 and PT11 on 2 different machines. I still use 10 a lot because of the sheer number of VST plugins I have which are useless in PT11 unless they are fully 64-bit and can be imported into 11 using BlueCat Patchwork etc.
Compelling upgrade reasons DiegoFox 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 11 12-26-2010 03:00 PM
If you need reasons to upgrade to Vista, here they are! 3JDamon 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 12-11-2007 09:57 AM
PT 6.4 Upgrade - Reasons?? Bob Gibson 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 06-09-2004 12:59 PM
Top reasons to NOT upgrade to OSX chuck.dallas Pro Tools TDM Systems (Mac) 46 03-10-2004 10:28 AM
Top Ten Reasons to Upgrade to 6.xx ThatHitSound 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 17 07-09-2003 12:53 AM
