No sound in Windows
Hi all.
I have a Dell PC running Windows 7 Home with a DigiDesign 002 running Pro Tools 8. In Pro Tools everything is fine but I don't get an sound from any other Windows applications. I have the Playback device set as S/PDIF (but have tried the other options with no success). Can anyone point me in the right direction please? I've had a bit of a search on these very forums but not found a solution. |
Re: No sound in Windows
Do you get sound from Windows Apps when PT is closed?
Too much blood in my drugstream Motherboard: Gigabyte Z690 AERO D CPU: Intel Alder Lake Core i9-12900K CPU Cooler: Noctua NH-D15S RAM: Corsair Vengeance DDR5 64GB (2x 32gb 5200MHz) Drives: 2 x Samsung 980 Pro 2TB NVME PCIE 4.0 M.2 SSD (Record & Samples) 1 x Samsung 980 Pro 1TB NVME PCIE 4.0 M.2 SSD (OS Win 11 Pro) GPU:Gigabyte GeForce RTX 3060 12GB GDDR6 PCIE 4 PSU: Corsair HX Series HX850 Platinim CASE: Fractal Define XL R2 PT 11HD (v11.3.2) Omni s/pdif <> AxeFxIII HD 96I/O |
No-nothing at all.
No mute button engaged on the 002/power amp to monitors?
Definitely not, no. |
Are you running PT version 8.04 or higher?
Make sure you have the latest drivers and re-install them with 002 switched off then reboot with it switched on.
One simple solution is to use the onboard audio for all non-Pro Tools sound. Feed a cable(stereo mini to dual RCA) to the Alt inputs on the 002 and push the Alt to Mon button to listen to all non-PT sound.
BTW, "Playback set to SPDIF" could be a SPDIF output on the motherboard. I use that to feed the SPDIF input of my Presonus Central Station for all of my non-Pro Tools audio(sounds much better than the mini plug analog output). There's no easy way to route that thru the 002.
Thanks for your help-muchly appreciated |
No sound on Windows 7 64 Bit SP1 | gfl1 | Pro Tools Express on Windows | 2 | 07-27-2013 06:27 PM |
windows 7 no sound with realtek HD | thetriangle | Windows | 5 | 01-30-2013 04:05 AM |
No sound in windows, on XP ptle74 | Darryl D | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 11-17-2007 05:20 AM |
No sound in windows | Raab | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 09-15-2006 01:56 PM |
Sound Recorder in Windows XP Pro | klwilbur | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 04-17-2004 07:20 PM |
