Old 02-12-2010, 02:14 AM
cpt cpt is offline
Default volume automation
Is there a way to get the transitions of a volume curve smoother at the beginning and the end of a region when you pull down the volume line with the trimmer tool ? Without doing it manually ?
Any tricks or shortcuts ? Thanks for any suggestions.
Old 02-12-2010, 02:21 AM
Default Re: volume automation
make a small selection on the curve and hit "x". This will draw a linear line in the range of the selection.
Obviously there is no automatic way of doing this.
On the other hand: since there is no audio before and after the region, what to you want to smooth out there in the first place?
Old 02-12-2010, 02:31 AM
cpt cpt is offline
thanks for your answer , if I have a voice over I select the region of the voice file , move the selection down to a aux fader and pull the master of the rest down , but the selector tool draws a vertical line and i have to edit it afterwards.
Old 02-12-2010, 04:12 AM
The quickest way I know is the one i mentioned above. I don´t see a way how this could be done automatically. There´s no way for the machine to know how long or in what way (linear, or some crazy curve) you want to smooth out the transition.
Another option is the "glide to" option but it´s more complex to apply than the method I mentioned.
Old 02-12-2010, 04:31 AM
crizdee's Avatar
crizdee crizdee is offline
Brilliant! how have i missed that all these years
Chris
Producer, Engineer,
www.ukmastering.com
Old 02-12-2010, 05:34 AM
cpt cpt is offline
thanks a lot , x is very helpful and a lot quicker!!
Old 02-12-2010, 07:18 AM
audioluche audioluche is offline
Chris
Same thing here....
Thanks Frank!!!!!!
Old 02-12-2010, 07:26 AM
Fidelis Fidelis is offline
Yes!!! Thanks man. I always did it by hand!
But I think DIGI could implement something different here. I think we could have a preference for making a very small smooth volume curve at the beginning and the end of a region when you pull down the volume line with the trimmer tool. That would be GREAT. I can not see a reason why this works like this...
Anyway, thanks.
http://www.ricardomosca.com
Hackintosh, 3,7 GHz 10-Core Intel i9, 64 GB 3200 MHz DDR4, OSX Catalina 10.15.7, PT HDX 2023.9.0, SSL 4040G+, tons of outboard
Mac Book M1 Pro, 16GB RAM, OSX 23.6, PT Studio 2023.9.0
Old 02-12-2010, 10:31 AM
c-tone c-tone is offline
Agreed. It would be similar to the auto fade in/out preference that exists now, with a user-defineable slope time. Both features can get rid of unwanted glitches, clicks and pops.
www.clifnorrell.com
Old 02-12-2010, 01:30 PM
BaileyBass BaileyBass is offline
Chris
Chris... Steve McMillan shared that on the DUC about 2 years ago, and your response was Exactly the way I felt when I read it then. There is a guy in Austin who has shared a lot of knowledge with me over the years.. when I showed him that one, he was so impressed with the amount of time it would save him over the rest of his career, he said "let's call it even". SB
Volume Automation.. thierryhenry Pro Tools 10 5 01-05-2013 12:46 PM
Converting Volume Automation to Clip Gain = Higher Volume! EricWillhelm Pro Tools 10 8 11-01-2011 11:12 AM
FCP, OMF & volume automation idris Post - Surround - Video 9 09-03-2010 08:06 AM
Volume Automation Bezo 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 12 11-10-2003 02:23 PM
volume automation ignored cyberdote Pro Tools TDM Systems (Mac) 5 06-21-2000 02:59 PM
