Go Back   Avid Pro Audio Community > Pro Mixing > Pro Tools | S6
Old 04-30-2019, 01:34 PM
beanbagjimmy beanbagjimmy is offline
Default Plug-in COMPARE Button on S6
Hi guys,
I've used the search function as well as looked in the S6 Guide and can't seem to find this anywhere...
From the S6, is there a way to toggle the COMPARE button in the Pro Tools Plug-In window.
Thanks for your help and sorry if this has already been addressed.
Old 04-30-2019, 02:33 PM
creativecontrol's Avatar
Default Re: Plug-in COMPARE Button on S6
Greetings,
No - you are not mistaken. The following are not currently represented on the S6:
Compare / Set to Default
Safe
Preset Management
Cycle can be accessed from the Process Module DYN or EQ buttons. Bypass is currently available in channelstrip view via the Process Module as well as within attention expand zones.
Jeff
Jeff Komar
Applications Specialist, Pro Audio
Old 04-30-2019, 02:35 PM
Thanks alot Jeff!
'Compare' button being automated? Soundburst ICON & C|24 0 12-11-2012 08:20 AM
Plug-in button and prefs jimlongo ProControl, Control|24, Command|8 0 06-28-2006 08:19 PM
Soundtoys v7.0 compare button Jazzbass56 Pro Tools TDM Systems (Mac) 0 12-16-2005 10:02 AM
C24 Bug - Window Button / Plug & Pan hanz marathon ICON & C|24 1 02-06-2005 10:04 AM
Plug-in Button lights up iamstudios ProControl, Control|24, Command|8 0 06-29-2001 01:55 AM
