SD2 issue
Hey folks, I built a new machine with an i7 950 and 12GB of RAM on an X58 mobo and all seems dandy(so far), but I am having an issue with SD2. I have sessions from the old rig that I copied to a new recording drive in the new rig. I installed SD2 the same as on the old rig, with libraries for the kits on a 3rd samples drive. The old sessions open fine and I can see the midi info on the instrument track(and midi action on the meter up top in the "instruments" box. But the midi will not "play" the plugin. I can click on the drums in the plugin and they play fine, but the midi on the piano roll does nothing. The plugin responds fine to me playing midi via my Roland TD10 kit, but no midi is recorded on the track. I guess tomorrow will be spent reinstalling it all unless someone has an idea.
A little followup; ezdrummer works perfectly, but SD2 is not. Guess I need to reinstall.......blah!
Re: SD2 issue
Hey Albee. You've probably already tried this, but if not, try duplicating the track and see if it plays on the new track. I've had that problem before with SD2 and Strike and that's fixed it for me.
Re: SD2 issue
Thanks, but I beat you that one. Its odd as h*ll. My Roland kit will play the sounds great but no midi appears on the track in record, and no midi I put on the track(with the pencil tool) will make a sound. Remove SD2 and insert ezdrummer and all works great. Go figure
Re: SD2 issue
You've probably already checked...but does SD2 have an update for PT9?
003r/i7-930/LE 8.0.1 cs2 on xp |
Re: SD2 issue
Didn't check because I have the exact same install on my other system(also PT9) and it works perfect on that rig. I'll just try reinstalling the package.
PT 9.0.6 Start/Stop Issue and Plug-in Instrument Issue | ZDF | macOS | 0 | 01-14-2013 02:47 PM |
weird crash issue PTx and possible procontrol issue, need help | Cryos | Pro Tools 10 | 5 | 12-08-2011 05:17 PM |
Some regions had invalid bounds... non-issue becoming a crash issue!!! | krichu | Pro Tools 9 | 3 | 12-11-2010 04:49 AM |
Digi 002 Power Harness Issue or Firewire Chip Issue? | Nish | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 35 | 05-07-2010 01:25 PM |
002 Console Issue, Faders Wont Move (grounding issue?) | guitar486 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 03-01-2010 03:58 PM |
