Old 02-28-2019, 09:40 AM
Steve@ZooWest Steve@ZooWest is offline
Default Remove Overlaps Not Working?
Windows 10 Pro/PT 12.4
After selecting a MIDI region where there are overlapping notes (Trilian bass in this case), I go to:
Event Operations
Duration
Select "Remove Overlaps and Leave Gap"
I input a small gap size: .010
No other boxes are checked.
I expect the overlapping midi notes to shorten appropriately so there are no overlaps, but there is no change to the midi notes in question. Am I missing something?
"Modern manufactured music is like art they sell at a furniture store."
http://www.weddingmusicproject.com/
http://www.weddingmusicproject.com/w...music-samples/
http://stevemillikan.com/
Old 03-01-2019, 10:44 AM
Tweakhead Tweakhead is offline
Default Re: Remove Overlaps Not Working?
Are you fully paid up on your MIDI Overlap™ Subscription ?
... but seriously . . .
What about if you double-click on the region and enter the MIDI Edit Window, and select all the actual notes there. Does it behave the same ?
Old 03-01-2019, 12:22 PM
That doesn't work either. I can, however, select Legato/Gap, and accomplish the same thing, which leads to the obvious question, why do both "Legato" and "Remove Overlaps and Leave Gap" have what appears to be the exact same function regarding midi notes? (Legato has an additional add overlap function that is not redundant). Not curious enough to look it up in the manual, since there is a way to do what I need to do.
Remove overlaps and leave gap... Stig Eliassen Pro Tools 10 18 08-30-2016 02:33 AM
midi event operations 'remove overlaps' doesn't work Dan Gralick Pro Tools 9 1 11-01-2011 05:36 PM
Midi export creating note overlaps + gaps tombliss 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 9 12-18-2010 10:13 AM
Bouncing Quicktime video - intro plays slow, overlaps middle vision, then no credits. accession 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 09-19-2009 06:06 AM
Add/ Remove Programs will not Remove Pro Tools powerjoe 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 09-07-2005 02:48 PM
